89 stalls
Old Jun 14, 2010 | 10:04 AM
kito1989's Avatar
kito1989
Default 89 stalls
HI, can any one help??? 1989 vet that starts,drives for about 1-2 mins then stalls out, new fuel pump, new fuel line with new fuel filter, getting good spark, will start after about an hour, then does exact same thing.
Old Jun 14, 2010 | 10:12 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
If your injectors are stock Multecs, OHM test them(cold then hot), should be around 16-17 ohms. If they are any with low resistance, they could be knocking out the ECM's injector drivers.
The ignition module could also be a suspect.
Old Jun 14, 2010 | 10:14 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Have you checked fuel pressure at the rail? If so what is it doing. Does it stall out while idling after a cold start? What is your coolant temp when it starts to stall?
AGENT 86's Avatar
AGENT 86
Check out Jon's thread on Multec injector problems and Ohm testing.
http://forums.corvetteforum.com/c4-t...questions.html
Old Jun 14, 2010 | 10:15 AM
kito1989's Avatar
kito1989
tks for replying, how do u check voltage on the injectors...
Old Jun 14, 2010 | 10:18 AM
kito1989's Avatar
kito1989
ty for your help, ill get back to you after i check voltage..
Old Jun 14, 2010 | 10:48 PM
kito1989's Avatar
kito1989
installed new ignition module, does same thing, seems like its flooding itself out, also found that after car idled for a min then stalled out, that the drivers side header was not nearly as hot as the passanger side header.
Old Jun 14, 2010 | 10:49 PM
kito1989's Avatar
kito1989
yes stalls out right after cold start. seems like its flooding.
Old Jun 14, 2010 | 10:55 PM
kito1989's Avatar
kito1989
coolant temp is very low.
Old Jun 14, 2010 | 11:08 PM
AGENT 86's Avatar
AGENT 86
Have you ohm tested the injectors ??
Have you tested both injector fuses ??
Old Jun 14, 2010 | 11:13 PM
kito1989's Avatar
kito1989
where r the injector fuses, gonna check the ohm's tomorrow.
Old Jun 14, 2010 | 11:26 PM
jfb's Avatar
jfb
Inj fuses are in the fuse block, use an ohmeter, it has better eyes than you do. Pull error codes and perform diagnosis for any codes from your electrical service manual. Measure the fuel pressure, it should be 35-42 psi and after the ign is off, pressure should hold up for a long time or you have leaky injectors or defective check valve in the fuel pressure regulator. You can check for injector pulses with a noid light (available at parts stores), or you can make your own with an LED (light emitting diode) and a series 680 ohm resistor. You unplug an injector and connect the light to the harness plug, it should pulse with the engine running or cranking. The homemade light must be connected with the proper polarity to the injector plug. D.C. ohms will only find gross injector coil failures, you really need an impedance bridge which measures the inductance and the Q of the coil. You might have a defective spark coil, bring a grounded wire to the boot of an unplugged spark plug while someone cranks a few revs, you should have a snappy at least 1/2 inch spark. If when it quits and won't immediately restart, spray some starter fluid into the MAF and if it starts, you have a fuel problem.
Old Jun 15, 2010 | 10:59 PM
kito1989's Avatar
kito1989
im pretty sure its a fuel problem, today i replaced the coolant temp sensor & pigtail, pigtail had little rust inside,didnt fix the problem, i did notice now when i turn over the fan turns on right away, going to measure the fuel pressure tomorrow & replace the fuel pressure regulator.
To 89 stalls
