adjustable coolant fan temp switch ? where
Old Jun 15, 2010 | 09:24 PM
turbodiesel's Avatar
turbodiesel
Default adjustable coolant fan temp switch ? where
could u guys point me in the right direction , i wanna be able to adjust my coolant fan to a certain temp when it turns on ,
i guess stock it turns on at 225? ...thats hi i wanna turn it down to 200 or so ..right?
thx 4 the input
what do i need and where do i get it ..thanks alot
Old Jun 15, 2010 | 10:21 PM
chileverde's Avatar
chileverde
what year is your corvette?
Old Jun 15, 2010 | 10:24 PM
turbodiesel
1987 thx
Old Jun 15, 2010 | 10:38 PM
rodj's Avatar
rodj
The only ones that are adjustable ( and cheap ) are the ones that have a probe that fits in the top radiator hose.They have a adjustment that lets you set temp.
http://www.summitracing.com/parts/FLX-31147/
Most people just install a fixed switch in the head that gives the desired operating range ,wire that to the relay bypassing the computer control and don't worry about adjusting it
http://www.mamotorworks.com/corvette...20fan%20switch
Of course there are more expensive fully electronic adjustable units
http://www.summitracing.com/parts/DAK-PAC-2700/
Old Jun 15, 2010 | 10:40 PM
chileverde's Avatar
chileverde
ok, your fan is controlled by a cooling fan switch, and it's set to switch on at 108C (226 deg).
you can go three routes from what i can tell...
1. manual override switch - tap into the field lead of the cooling fan relay harness and connect up a toggle switch, one wire to the tapped wire, the other to ground (grounding out the field lead on your relay activates the fan)
2. low temp cooling fan switch - There is a 100C (212 deg) temp cooling fan switch that fits where the original one goes, GM p/n 3053190.
3. aftermarket cooling fan thermostat kit - you can piggyback this into one of the fan circuits and make it adjustable.
Hope that helps.
Old Jun 15, 2010 | 11:00 PM
turbodiesel
AWESOME thanks man
sounds like i will just pop a GM p/n 3053190 , in there for now.
thanks
Old Jun 15, 2010 | 11:01 PM
turbodiesel
where is the switch at?
rodj's Avatar
rodj
The original switch ( if fitted ) only controls the aux fan in front of radiator.New switch needs to be wired to the main fan to control that as well
Old Jun 16, 2010 | 12:37 AM
chileverde's Avatar
chileverde
if that's true thats an easy fix, just swap out the primary/secondary field wires between the two relays, or run a jumper connecting them both together so they come on at the same time.
Old Jun 16, 2010 | 01:49 AM
rodj's Avatar
rodj
if that's true.
Main fan in '87 is controlled by the ECM. Only '84 had main fan from mech switch
IF you have a Aux fan fitted in front of radiator there will be a existing switch in the drv side head between # 1 and 3 spark plugs.
If not that, plugged hole is where you new switch goes
Old Jun 16, 2010 | 04:13 AM
turbodiesel
yes so the main fan thats behind radiator motor side, how do i get that to turn on b4 226 like 200-210
thx
Old Jun 16, 2010 | 04:26 AM
rodj's Avatar
rodj
As noted above .
You splice into the wire that goes to the computer from fan relay
( that way the computer will still run your fan if the switch fails ) and connect that wire to the new switch along with the old wire
( if you have aux fan )
Requires running a new wire from main fan relay to switch in head
Old Jun 16, 2010 | 04:34 AM
turbodiesel
ok so sum vettes have 2 fans 1 on each side of the radiator?
so if i wanna turn it on sooner run a hot wire to the one wire ur talking bout so i can turn fan on when ever, just a toggle switch and sum wire? ...
Old Jun 16, 2010 | 05:04 AM
rodj's Avatar
rodj
It is not a hot wire.
It is a wire to ground to turn the relay on.
Same way as above ,just that you run the wire inside to a switch that goes to ground
Turn the switch on ; fan runs.
Switch off ;the computer runs the fan
Old Jun 16, 2010 | 05:08 AM
turbodiesel
ahhhh ok so get a good ground connect it , then to switch , then run another wire from switch the relay , then when i turn switch on , making the 1 wire a good ground , it will turn the fan on..? then im set right? ..
Old Jun 16, 2010 | 09:15 AM
rodj's Avatar
rodj
You got it
Old Jun 16, 2010 | 06:59 PM
chileverde's Avatar
chileverde
For what it's worth, I just installed a low temp fan switch and wired it into my secondary fan of my '94, and it's working great.
Since the LT1 doesn't have a cooling fan switch sensor between #1 and #3, I installed a kit consisting of a brass tee, a 212 deg (+/- 8 degrees according to specs) GM fan switch, the electrical sensor wire connector, and wire tap for the relay field wire (dark blue for secondary, dark green for primary).
Now, the temp gauge reads 207 deg. when the fan switch kicks on and shuts off at 197 deg. No more 230 degree stoplights!
Rob
To adjustable coolant fan temp switch ? where
Old Jun 16, 2010 | 07:31 PM
rodj's Avatar
rodj
Since the LT-1 doesn't have a cooling fan switch sensor between #1 and #3, I installed a kit consisting of a brass tee,
Could have put your new switch in the hole between #6 and 8 .No tee needed
Old Jun 16, 2010 | 08:17 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
That location has the temp variable resistor for the temp gauge, it is not a switch.
Old Jun 16, 2010 | 08:38 PM
rodj's Avatar
rodj
I thought the temp gauge sender on a LT1 must be on LH side which is why he used a tee to mount fan switch and gauge sender?
