i just purchased a 85 vette and im having trouble with my gauge cluster, only the turn signal will work, i took the cluster apart and it looks clean and the bulbs are fine. i looked at the wiring cluster under the dash and it is a mess. there is a aftermarket box, spliced wires and unconnected wires.
any suggestions would be appreciated
also looking for any wire diagrams that would also be wonderful
for some reason i cannot post attachments
if you are sure the bulbs are not burnt out or corrosion on the connections then you will have to trace that wiring back to fuse panel to the cluster fuse. if you don't have a FSM with a wiring diagram then buy a haynes manual it will help with the wiring. better yet start at the fuse panel and work your way toward the cluster since you have unconnected wiring. it will be grunt work but it sounds like it is necessary.
Worst case by a used dash harness off of EBAY. It should at least have all the proper connectors on it. What kind of aftermarket device is attached? Are you talking about the ECM Computer?
Woody
