Bolt torque question
Old Jun 19, 2010 | 09:34 PM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
Default Bolt torque question
Hi all, got a question I could use some input on. Replaced the right-front
hub assy. on my 91 due to excecive play. While Torqueing the first 2 bolts
(specs. call for 47ft. pounds of torque) checked my settings cuz something didn't seem right, no click. Was actually set 70. Backed them off and re torqed to the correct setting. Did I do any damage to the
bolts?? This is really bugging me, what you'all say.
Old Jun 19, 2010 | 09:37 PM
Pete K's Avatar
Pete K
Maybe. The bolt manufacturer will have a maximum stretch point that will ruin a spring by not allowing it to return to size when loosened. Trying to determine what that max number is will be near impossible.
Old Jun 19, 2010 | 09:39 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Old Jun 19, 2010 | 09:48 PM
The Green Hornet
Looks like I'll be heading to the chevy dealer to pick up some new bolts.
It'll at least give me peace of mind. Thanks for the replys.
Old Jun 19, 2010 | 09:55 PM
samsonb's Avatar
samsonb
Yeah, that would probably be best. What torque wrench was it? I've been using a Harbor Freight.
I bet that front hub was alot easier than the rear hub I just got done replacing. Haha.
Old Jun 19, 2010 | 10:30 PM
batchman's Avatar
batchman
I wouldn't worry about it. With a straight torque value these aren't the "torque to yield", therefore stretch is not a big problem. If you're worried then re-check the torque after a week.
I've been changing these frequently and have been using German spec (goot 'n tight). Wasn't aware of the torque value. Will adopt. Haven't had any problems, and again I'm servicing these a couple times a season.
Best,
- Jeff
Old Apr 3, 2022 | 03:46 PM
81C3BUILT's Avatar
81C3BUILT
Default torque fiberglas rear spring with load on suspension
(specs. call for 47ft. pounds of torque) checked my settings cuz something didn't seem right, no click. Was actually set 70. Backed them off and re torqued to the correct setting. Did I do any damage to the
So I did my control arms bushings, u-joints, diff fluid change, and now time to put on the rear composite leaf spring 3 long bolts. I put never seize on them to get accurate torque reading and began to tighten them all the same turns in unison, When i got them torqued to the Corvette Brakes suggested 75 foot pounds, the spring was still loose. Then I read more thoroughly and instructions state tighten with load on suspension". As soon as I put full load on rear leaf the bolts were loose again, I torqued each with full riding load and never had to tighten again
To Bolt torque question
