alternator output
Old Jun 20, 2010 | 07:07 PM
Tom 35th anniversary's Avatar
Default alternator output
What should i be reading at the battery when I measure voltage with the car running. I suspect my alternator is going south. It measures 13 - 13.5 volts when the car is running. Should it be closer to 14 volts? Everything went dim last night and blew the gauge fuse. This is the second time this has happened in a couple of months. Fuse blows, then I lose A/C, and torque converter lock up. But this time didnt seem to be charging right.
Old Jun 20, 2010 | 07:09 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
It should read 14.0 - 14.5v
Old Jun 20, 2010 | 07:16 PM
Damn!!! That alternator is less than a year old. Guess I'll take it off and have it tested. I doubt the alternator is part of the fuse blowing problem though.....
Old Jun 20, 2010 | 07:20 PM
MK 82's Avatar
MK 82
The voltage will depend on the state of the battery and how much current you are demanding. Anything over 13 is charging.
Turn the high beams on and the AC fan to hi and then tell us what the voltage is.
Old Jun 20, 2010 | 07:27 PM
Last night as I was pullin up to the house with high beams on a/c off cause fuse was blown I flipped on the dash gauge and it was at 8 volts. Wierd that it metered out at 13 today though.
Old Jun 20, 2010 | 08:13 PM
MK 82's Avatar
MK 82
What was the load when you read the voltage?
Old Jun 20, 2010 | 08:17 PM
BADDUCK's Avatar
BADDUCK
Check the alternator and battery terminals and make sure they are clean and tight. Charge the battery tonight. Check the voltage in the morning after warm up with and without accessory load.
Old Jun 20, 2010 | 08:25 PM
Weav's Vet's Avatar
Weav's Vet
I actually get 14.7 at times
hooked073's Avatar
hooked073
A couple of things check the voltage at the out put terminal of the alt, then check it at the battery, and then what it is reading on the gauge there should not be a 1/2 a volt difference between the 3. Pull the positive term off the battery while the car is running and see what your voltage is then should be right around 13.5 to 14.5. But I do not think this is what is causing your fuse to blow. fuse are a safe guard for excessive amps. I think your fuse blowing must likely is lock up related or A/C related. lockup selonoids have had problems with shorting out. and A/C clutches are also know for high amp draw as the get older. Could also be a short in either of these areas.
Old Jun 20, 2010 | 08:40 PM
Thanks for all the responses guys. As soon as I get some time I'll ring it out. If its not one thing its another, but I'm becoming quite the junior hammer mechanic!!
Old Jun 20, 2010 | 08:57 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
Please don't let a hammer get anywhere near your Vette.
I would never disconnect a battery or alternator while the engine is running. Invest in a new battery and an alternator ($200) for the peace of mind. Keep that 35th on the road where it belongs.
Old Jun 20, 2010 | 11:17 PM
hooked073's Avatar
hooked073
paksr I am lost you would throw 200 in parts with out even trying to dianose the problem and most likely have nothing to do with the blown fuse. checking the voltage at the 3 spots I suggested is just a fast way to look for voltage drops at a couple of major places. disconnecting the positive cable while running takes all the vehicle load off the alt giving you what the alt is putting out ie a bench test to the vehicle. I have been doing these tests for 33 years and never once caused a problem. They are also taught in basic automitive electronics and even in some form of questing on ase testing
Old Jun 21, 2010 | 07:15 AM
walter schweigert's Avatar
walter schweigert
FWIW, I always get a direct battery reading which is .3 volts higher than what the dash gauge reads.
I also would NOT pull the Positive terminal with the engine running.....too much Voodoo.
Old Jun 21, 2010 | 11:12 AM
redrose's Avatar
redrose
last week, local 'asse certified' hero said he needed to charge his boat batt and started his truck, pulled batt cables off truck batt to switch boat batt in, few seconds later with no batt in the truck quit, won't restart...hero thinks the ecm is toast, no idea why sudden death.
shirt-tail relative bought a gorgeous 02 caddy a couple months ago for stupid low price, MIL was on (failed state inspection), dash lights all wacky, started good but ran rough, and numerous other probs...PO was told by his mechanic that it needed $4000 repairs, maybe more...first repair we did was a new $95 (list price, not actual) batt, everything except a few dark bulbs went back to showroom condit.
your horse, you can put the saddle on facing front or rear as you choose.
Old Jun 21, 2010 | 11:16 AM
vader86's Avatar
vader86
My in-car gauge is about .5 V different from actual, so don't trust the in-car gauge.
It should be about 14.0-14.5 when the car is cold, as it heats up it'll drop into the 13s.
Old Jun 21, 2010 | 12:32 PM
hooked073's Avatar
hooked073
Vader that is what I was talking about. When you say actual you are getting a reading from the batt or back of the alt. If you were seeing a volt or more and I was having problems that is when I was looking backwards.
I will stand by the testing of unhooking the post for testing and also that fact that it would not hurt a thing. There is no vooodoo no majic or stranges things going to happen it is a field test and a simple way to bench test an alt....
To alternator output
