Pushrod guide plate problem...
Old Jun 21, 2010 | 05:34 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Default Pushrod guide plate problem...
I have a set of 3/8" push rod guide plates on an engine that has 3/8" stock, not hardened (I assume) pushrods.
The push rods keep wearing out/through the guide plates. I just pulled the valve cover today to replace a cover gasket and was shoked to find that the rods are well on there way to wearing through a 2nd set of guides. (!) There is absolutely NO discernable wear to the pushrods at all. I don't get it.
Flat tapped cam, 113 heads, Summit Racing Guides, and NON self-aligning, stock rockers.
I thought thatthe need for hardened pushrods was b/c the rods would wear out...not the guide plates. Non-hardened rods will wear out guide plates?
Old Jun 21, 2010 | 05:42 PM
USAsOnlyWay's Avatar
USAsOnlyWay
Pictures?
I've had ARP guide plates with Moroso hardened pushrods and nothing of that sort occuring.
Sounds like some serious alignment issues but hard to say anything without seeing it.
Old Jun 21, 2010 | 08:11 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
The machining on some of these lower cost guide plates is not great. I have Comp hardened guide plates and pushrods and have had no problems. Additional info sent in PM.
Old Jun 22, 2010 | 01:19 AM
tpi 421 vette's Avatar
tpi 421 vette
Hi Tom, That is weird. I have always seen wear on the pushrods before wear on the giudeplates. I would try some good name brand guideplates as mentioned.
Old Jun 22, 2010 | 01:03 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
10-4. I guess that is probably the logical thing to do. Here are pics, for anyone who is interested...
Cam is not 'high lift'. It is a comp, flat tappet. 210/218, and something like .450 lift. Springs are stock '90 vette springs.
I don't know what do do, other than throw another set of guides pushrods in it. I was under the impression that using non-hardened pushrods, w/guide plates would cause PUSH ROD wear. Not guide plate wear. I don't get it. Guide plates are "Engine Pro" brand.
Old Jun 22, 2010 | 07:54 PM
John A. Marker's Avatar
John A. Marker
1) Buy some good hardened guide plates.
2) What is the diameter of your rods? It doesn't look like there is much clearance between the rod and the plate. This might be contributing to your problem.
3) If your rods are not wearing and are still straight (roll them on a glass surface to test) then keep using them and just get the correct guide plates.
Check out this post...the pisture at the end. Look at the rod on the left side of the picture....looks litke much more clearance than what you have.
http://forums.corvetteforum.com/c4-t...-question.html
Old Jun 22, 2010 | 08:11 PM
Bondami's Avatar
Bondami
From: Southside of Western Norte Americano State of Confusion, ColoFornia
St. Jude '13
Perhaps Im missing something here. But why run the guide plates at all??
Stock rockers, flat tappet cam, not super excessive valvesprings.. why are the guide plates needed is it because of the heads? It would seem the stock rockers are fighting the plates while trying to find where they want to run.
honestly just curious.
Old Jun 22, 2010 | 08:24 PM
383vett's Avatar
383vett
As mentioned, get some good quality guideplates and your problem will be solved. To answer why guideplates are needed, without guideplates, the hole in the head that the pushrod goes through provides no lateral stability for the pushrod. Without guideplates or self aligning rocker arms, the pushrods would push the rockers at an angle and the rockers would fall off the tip of the valve which would result in a "kaboom" type noise that would require $$$ to repair.
Old Jun 22, 2010 | 11:13 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Eh, that's about what mine looked like when I put them together. Stock, '77 5/16 rods and 5/16 guide plates.
Thanks for reading and looking.
Old Jun 22, 2010 | 11:38 PM
John A. Marker
I am assuming that the 5/18 is a typo. So you are putting a 5/16 rod into a guide plate manufactured for 5/16" rods. I just checked out Jeg's and that is how they advertise the plates. So I would have to guess that there is clearance (however small) between the plate and the rods.
I have to believe that the plates you have were not processed properly during the hardening process or lower grade materials were used. You should not be wearing the side of the plates. Go with a name brand guide plate.
Here is a picture of a push rod in the guide plates on my AFR heads. You will note the broken screw in stud!! Damn...happened on the road. These plates came with the heads and have about 40,000 miles on them. I had to go to a shorter rod with my LPE 74211 roller cam and roller lifters. But the old rods showed no signs of wear.
These plates have Air Flow Research (AFR) stamped into the plate, although they may have been made by another company for them.
Old Jun 23, 2010 | 03:20 AM
Bondami's Avatar
Bondami
St. Jude '13
I guess thats what I was asking.. Those rockers sure looked like the typical self aligning stamped steel stockers..I see now where the OP said they were NONself aligning..
(so thanks for answering what appeared to be a very dumb question with class. )
Old Jun 24, 2010 | 11:56 AM
USAsOnlyWay
Interesting and disappointed, I have Summit full roller rockers from when they were made by scorpion and they work great. I wouldn't have expected this quality from Summit brand parts.
Are the pushrods that are wearing the guide plates being pressed on at all by the heads? I know on some stock heads some clearancing is required and maybe that is why you have some guide plate wear going on...?
Old Jun 24, 2010 | 01:52 PM
JAKE's Avatar
JAKE
I'm confused.
Also, 3/8", not 5/16"?
Jake
Old Jun 24, 2010 | 02:23 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I would first check that there are no self-aligning tabs on the rockers and no "indents" worn into their tips.
If the rockers look ok, get a set of CC hardened push rods & guide plates.
Old Jun 24, 2010 | 02:45 PM
engle1147's Avatar
engle1147
The stock lifter to pushrod & rocker to valve stem setup is messed up because the valve stem centerline is wider than the lifter's centerline. This is more noticeable with the higher ratio lifters that will tend to sit more off on the sides of some of the valve stems.
Use an adjustable guide plates to make the rockers line up with the valve stems: http://www.summitracing.com/parts/AFR-6104/?rtype=10
or
pickup some offset rockers: (example not the correct fit): http://www.summitracing.com/parts/CRO-72801X1-8/
or
Pick up a set of stamped self aligning rockers and call it a day. The ones below were from a stock '89:http://shop.advanceautoparts.com/web...1_900494043___
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
1. CORRECTION. I thought that we had bought the guide plates from Summit, but I was wrong (this is a "company truck" so I didn't buy the parts myself -my parts person did). They are "ENGINE PRO" brand guides.
2. The heads don't touch the push rods. The rod-hole is ample size and then some, for each push rod.
Old Jun 24, 2010 | 02:46 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by JAKE
I'm confused.
Jake
Another error on my part. you are RIGHT; they are 5/16 rods and 5/16 guides.
To Pushrod guide plate problem...
Old Jun 24, 2010 | 02:51 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
or
or
Yeah. I should not need any of that w/my combo of very basic parts. I have a set of COMP guides on the way, and a set oc COMP hardened pushrods. I'll give that a whirl. If that doesn't work for some strange reason, I'll get some self aligning rockers.
Old Jun 25, 2010 | 08:19 PM
mtwoolford's Avatar
mtwoolford
I can't really see the style head you have from the posted pictures; but, I have a 350 out of an 86 or 87 CHP car; the heads themselves have very narrow slots where the push rods pass through; these are, in effect, the guide plates for that partcular engine; adding aftermarket guideplates to this style head could cause the type problem you're experiencing.
Old Jun 26, 2010 | 11:09 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I know. These are 113 heads; aluminum. No guides in the heads...you need guide plates or self aligning rockers.
