Quick Radiator Cleanup!!!
Old Mar 21, 2002 | 09:43 PM
GusBustamanteJr's Avatar
GusBustamanteJr
Default Quick Radiator Cleanup!!!
After reading how to remove the radiator and clean it in the tech tips section, I tried it on my 91. Apparently, the steps are not the same, and its a little more involved, I could not get the shroud off, so I quit. Now its getting warm down here in Miami and the car gets hot with the AC on in heavy traffic. I decided to try my own remedy.
First, I got my compressor and started blowing the ac cooler from under the front grill. I really blew it out methodically section by section. All sorts of stuff was flying around- wear a mask and goggles. Then I blew from the passenger side access hole in the shroud. I could still see it was furry or had some kind of nasty growth on the front of the radiator between the ac cooler. I couldnt get at it with air. I started thinking, and reached for my home ac coil fridge coil cleaner. It was perfect! I was able to clean the front of the radiator, back of AC cooler, front of ac cooler. I got the fur out! Dont ask me how that crap gets in there! then I blew it out again with more air. I did a flush just for added effect. Tomorrow, I will see if it runs cooler in the traffic on the way to work. I bet this could be a good maintenence tip to do every 6 months to keep it clean for those of you that have already cleaned it.
Old Mar 21, 2002 | 09:48 PM
No Go's Avatar
No Go
Default Re: Quick Radiator Cleanup!!! (GusBustamanteJr)
Yes your 91 (and my 96) is more involved.
Some have warned that using high pressure (water/air) can damage the heat exchangers...
I have used water with good success though..:)
Old Mar 21, 2002 | 10:04 PM
GusBustamanteJr
Default Re: Quick Radiator Cleanup!!! (No Go)
Is that a massager on your car? You take really good care of her huh?
Someone should change the tech tip to reflect for a 91-96.
Old Mar 21, 2002 | 10:09 PM
No Go's Avatar
No Go
:D
To Quick Radiator Cleanup!!!
