Ok while I was at the Garber auto mall tech shop they told me my brake light were not working. I checked the fuse all good.
Can someone who knows about how the 1990 corvette brake light system works tell me alittle about it. I'll be looking in my books to learn what I can but Idea will help.
All fuse are good. All bulbs are good. all turn lights are good. the brake switch has never been hooked up but the brake lights still worked. I can not find the wires that go to the brake switch I looked all over.
Im I looked inside my stoplamp switch and dont see any burn out or bad parts. Could that really be the problem? Im waiting on a voltage tester to see if it getting power or not. Up date when I do it.
I found the problem. It was a fuse, the fuse blew out in a hard to see spot. But, before I put the switch back I cleaned the inside out and put new grease in.
Good job, I was gonna offer to come by and help shove ya under the dash or pry ya back out. Good you solved it, it saved ya some bruises
