I need more air.........
Old Jun 24, 2010 | 03:53 PM
Weav's Vet's Avatar
Weav's Vet
Default I need more air.........
At least my tuner says I do. I finally got a WOT data log to him. I'm runninga OE intake with a cut lid and a K&N. Here's what he had to say........
Two things I noticed are that your airflow reading is not very high considering your mods. I would think it should be a good bit over 300 gm/s, but yours is just barely breaking that. The other thing is that your MAP reading is not staying close to 100 KPa at WOT, which usually indicates an airflow restriction or valve float (could be related to the low airflow reading).I would check out that in the meantime.
As far as the valve float I upgraded the springs on the AFR's to the next size springs(8019 I believe). I knew I was close to their standard springs with the lift I have plus the 1.6 rockers. Thoughts?
Spring specs
AFR-8019
1.270 OD Size
155# @1.810 Pressure
1.080 coil bind
428 Rate
650 Max lift
Premium Grade
Old Jun 24, 2010 | 04:04 PM
Aardwolf's Avatar
Aardwolf
You could try a simple air filter mod and see if it makes a difference. I read some posts from d48mclain about using two air filters. One with the filter media removed and used as a spacer. I was really skeptical of it working but give it a try. Here is what he said about it in email: "The single stock filter sits real close to the bottom of the intake and there isn’t much room for air to come up from the bottom. All the second filter is a spacer to open up the area so air can flow."
Old Jun 24, 2010 | 04:23 PM
bjankuski's Avatar
bjankuski
My estimate is that 300 gm/s is close to 475 HP at the crank. When I look at the mods in your sig this does not appear to be out of line. How low was the MAP reading? If the MAP reading is real low that would indicate an airflow restriction. The valve spring appear OK to me, how high do you rev the car?
Old Jun 24, 2010 | 04:34 PM
Weav's Vet's Avatar
Weav's Vet
94KPa was as low as I saw in the WOT file I sent him. It went up to 98 but only briefly.
Old Jun 24, 2010 | 04:49 PM
Weav's Vet's Avatar
Weav's Vet
In that particular file it hit 6300 rpm.
Old Jun 24, 2010 | 05:07 PM
bjankuski's Avatar
bjankuski
94 KPA is not that bad. You have some restriction but not a terrible restriction, if you could get the MAP pressure to 100 KPA you could pick up approximately 6% more power.
Old Jun 24, 2010 | 05:15 PM
Weav's Vet's Avatar
Weav's Vet
I've been looking at after market air intakes but the pickings are slim for anything that looks like it may help. There's a C5 twin filter one I may get and try. I'll have to do some kind of piping though to get it up to the MAF sensor.
Old Jun 24, 2010 | 05:27 PM
MK 82's Avatar
MK 82
Before you go reinventing the wheel-take the air filter element out and see what changes. The restriction may not be in the air cleaner part.
Old Jun 24, 2010 | 05:41 PM
Weav's Vet's Avatar
Weav's Vet
I can do that
Old Jun 24, 2010 | 05:57 PM
Weav's Vet's Avatar
Weav's Vet
Just a thought, maybe the Edelbrock LT4 intake is flowing better than it's reputation gives it credit for. Just a thought.....
Old Jun 24, 2010 | 06:36 PM
aboatguy's Avatar
aboatguy
If it were I'd think that the AFGMS would be higher than 300 gm/s....
What was the highest AFGMS you saw on your datalog....
Mike
Old Jun 24, 2010 | 07:00 PM
Weav's Vet's Avatar
Weav's Vet
Mike
314 gm/s
Old Jun 24, 2010 | 07:12 PM
Weav's Vet's Avatar
Weav's Vet
Could it something on the other end, the exhaust? I had the cutouts closed when I made this WOT run. How about cats? Partially plugged maybe? Headers 1 5/8, maybe 1 3/4 would be better. I mean the air has to get out as fast as it's coming in, right?
aboatguy's Avatar
aboatguy
314 gm/s
That doesn't seem too bad...I hit (315gm/s) around 6200 this time of year.
A while back I was looking for intake track improvements and I had lower MAF readings (at speed) with the airfilter removed so the filter was not a restriction on my car.
Old Jun 24, 2010 | 07:14 PM
Weav's Vet's Avatar
Weav's Vet
Well, this was really, really really early in the morning and the air was rather heavy.
Old Jun 24, 2010 | 08:38 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
could be the cats
how old are they
what did you install? (I see longtubes in you sig)
Old Jun 24, 2010 | 10:45 PM
MK 82's Avatar
MK 82
That is to your good. If you will notice, the flow is in weight/sec-not volume.
To I need more air.........
Old Jun 25, 2010 | 01:19 AM
Weav's Vet's Avatar
Weav's Vet
Originally Posted by BrianCunningham
could be the cats
how old are they
They are high flow bullet type and came with the Stainless Works headers. I guess about a year and a half old. maybe two. When I re installed the OE exhaust system I had them off. I could see through the honey comb inside if I held them up to a light. If I shook them they rattled like the honey comb inside was loose. Is that normal? One of them and I don't remember which looked like it had gotten really hot at some point. The outside casing had a bluish tint to it. All of this was before the head swap. About 3-4 months ago.
Down at the track last year in one of my moments of total stupidity I ran about 3 gallons of 112 octane through them. I was lower on gas than I had thought so I got that to make my runs and make sure I made it home. I guess there might have been 3 gals or less in the tank of 93 octane so it was a 50/50 mix more or less. I ended up replacing the O2's because of the lead and after that and it seemed to run ok so I didn't really question the cats anymore. (Lesson learned!) Now I am though since they are being put to the test here with exhaust flow.
Old Jun 25, 2010 | 01:20 AM
Weav's Vet's Avatar
Weav's Vet
I see, got ya.
Old Jun 25, 2010 | 07:15 AM
LT4BUD's Avatar
LT4BUD
If the MAP is dropping this has to indicate a pressure drop on the incoming side.....filter element, MAF, throttle body, ducting/housing....
really stupid thought, maybe your throttle body is not going fully open??
..for sure your problem, based on drooping MAP, is on the intake side
