Shakey Front Calipers
Old Jun 25, 2010 | 10:38 PM
Meds94's Avatar
Meds94
Cruising
Default Shakey Front Calipers
I recently had my front rotors and brakes pads changed on my 94. I have noticed a chatter ,clattering noise while driving. I also noticed I can feel the pads hit the rotors when I press the brakes. So i checked to see if the bolts were loose the big ones that mount the caliper and nope there tight, but i noticed i could still shake the actual caliper with the pads about a 1/8-1/4 in. is this normal? also noticed grooving in my rotors already (2weeks) new. And no I didnt change them, didnt have the time or tools yet. Am planning on taking back to shop it was done at. Heres the kicker took it to Chevy dealership first they said no brake problem, said it was flat spots on my tires. Did have a cracked rotor reason for change in the first place.)
Old Jun 25, 2010 | 11:35 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
It sounds like the shop neglected to install anit-rattle pads or compound behind the new calipers.
If my new brake pads do not come with such an insulator pad I coat the rear of the brake pads with an anti-rattle compound, available at my local parts store.
Old Jun 26, 2010 | 08:02 AM
Aurora40's Avatar
Aurora40
You can move it 1/8-1/4"? That is a *lot* of movement. The pads and caliper should not knock back that much at all. Do the rotors have a ton of run-out? Try rotating the rotor and see if it moves from one side of the caliper to the other as it rotates, if it has that much run-out you can probably see it visually.
Old Jun 26, 2010 | 08:39 AM
WW7's Avatar
WW7
Like mentioned above, they forgot the anti rattle clips.The clips hold the pads solid in the calipers so they don't move around. Been there done that......WW
Old Jun 26, 2010 | 11:17 AM
c4cruiser's Avatar
c4cruiser
The front calipers are held in place by a single bolt and a pin. The pin can wear over the years and there is a small C-clip that holds the pin in place. You can move the caliper up and down somewhat if the pin is worn. Could also be that the pads were not fully seated in the retaining holes on the pistons and the outside of the caliper bracket.
Anti-rattle clips are also needed as mentioned. Most aftermarket pads (non-GM) don't come with these clips. Anti-rattle clips, bolt and guide pin boot, and the pin w/ C-clip are usually included with a mounting kit. Some shops don't use a new mounting kit, they just use the old stuff and typically don't install new anti-rattle clips.
Grooving in new rotors with loose pads can result from road debris like tiny pebbles being caught between the pad and rotor face. If it isn't too deep, don't worry about it.
Old Jun 27, 2010 | 01:16 PM
Meds94's Avatar
Meds94
Cruising
Default Thanks
Thanks for all the feedback its back in the shop. Will be following up with them Monday.
Old Jun 27, 2010 | 01:45 PM
jhammons01's Avatar
jhammons01
Me too......I didn't know that clip slipped up through that hole.....So I left them......but only for a week......
The clacking sound was too much to live with...
To Shakey Front Calipers
