No blower on a 1986 Vette
Old Jun 26, 2010 | 08:03 PM
rrwebster's Avatar
rrwebster
Default No blower on a 1986 Vette
Just picked up my new toy...
if I push the buttoms for auto to bi-level etc I hear noises like stuff is moving but I don't have any blower action.
I just ordered a service manual... I removed all the connectors at the heater unit and blower and sprayed with contact cleaner... still nothing.
I push the heat and cool buttons and the temp changes...
Any thoughts?
thanks in advance for any input.
Robert
Old Jun 26, 2010 | 09:40 PM
rodj's Avatar
rodj
Try running 12V to the blower motor to see if it actually works first
if it does you have to work through the control side of wiring
Old Jun 27, 2010 | 12:15 AM
rrwebster's Avatar
rrwebster
is that the single pole input or the two pole input?
Old Jun 27, 2010 | 01:19 AM
rodj's Avatar
rodj
There is a plug on the blower motor.
Disconnect that and put 12V on one terminal and a ground on the other to see if motor runs
Old Jun 27, 2010 | 08:58 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Here is the HAVC electrical from my 86 FSM, should help diagnose the blower issue.
http://members.shaw.ca/dankai/HVAC%20Electrical.pdf
Here is more info on your HVAC, in case you need more info.
http://members.shaw.ca/dankai/HVAV'S.pdf
Old Jun 27, 2010 | 09:03 AM
rrwebster's Avatar
rrwebster
Agent86!!! terrific... thank you!
Old Jun 28, 2010 | 06:43 AM
rrwebster's Avatar
rrwebster
Blwer blows when I add 12v to it.
if I test the connector there... I don't have anything close to 12v.
Old Jun 28, 2010 | 09:11 AM
AGENT 86's Avatar
AGENT 86
Have you tested the required fuses and in and outs of blower module and control head ?
Old Jul 19, 2010 | 04:57 PM
rrwebster's Avatar
rrwebster
Turned out to be the two plugs that plug into the Blower Control weren't making good contact.
To No blower on a 1986 Vette
