right o2 sensor keeps failing
Old Jun 26, 2010 | 10:15 PM
ChrisLT1conv's Avatar
ChrisLT1conv
Default right o2 sensor keeps failing
I had my right o2 sensor fail awile back and relpaced it with a bosch _ I'm no fan of bosch but it was all I could find at the time , my 1994 vette run great for about a 3 weeks then the sensor failed again h64 well I took it back and replaced it now a month later this one has failed. The car runs great when I replace them and then when they go bad it floods horribly until the check engine light come on then it runs fine. I have a delphi o2 sensor ordered I'm just wandering if there is anything that could be causing this? I have a hard time blaming anything because the car runs perfect when I replace them and it runs great when the computer goes into closed loop. Do you guys think I got two pieces of crap from bosch or could there be an underlying problem?
Old Jun 27, 2010 | 10:15 AM
ChrisLT1conv
P.S. I also wanted to state that the car uses no oil whatsoever.
Old Jun 27, 2010 | 04:11 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Don't know but I am doing some research on an idle issue and I've read some very bad things about Bosch o2 sensors
Old Jun 27, 2010 | 06:01 PM
Weav's Vet's Avatar
Weav's Vet
The first tuner I had said never ever run Bosch 02's to always use GM.
Old Jun 27, 2010 | 06:17 PM
ChrisLT1conv
thanyou guys for confirming my suspicions
Old Jun 27, 2010 | 11:05 PM
RUU's Avatar
RUU
Anti-freeze from, say, a bad head gasket will destroy an O2 sensor in short order too.
Old Jun 28, 2010 | 01:58 PM
ChrisLT1conv
thankyou for the tip on that. I don't smell any antifreeze and I am losing no coolant. This is something to keep in mind though
Old Jul 1, 2010 | 12:59 PM
ChrisLT1conv
well I ordered a delphi and it comes in today. I will have my car back tomorrow so I guess it's a we will will see deal. The bosches lasted abot 1000 miles a piece
Old Jul 1, 2010 | 04:26 PM
Weav's Vet's Avatar
Weav's Vet
Come back to this thread after a couple of months if it makes it that long and let everyone know your findings.
Old Jul 1, 2010 | 04:32 PM
aklim's Avatar
aklim
If it isn't oil or coolant, what else is probable? Could the sensor be fouled out from a cylinder not working right?
Old Jul 1, 2010 | 04:33 PM
ChrisLT1conv
I will do that
Old Jul 1, 2010 | 04:36 PM
Weav's Vet's Avatar
Weav's Vet
I wonder what the voltage is it's getting? Maybe a bad wire or plug.
Old Jul 1, 2010 | 05:07 PM
ChrisLT1conv
I have new wires, plugs, new opti, new coil and new icm on the car. When I put a new o2 sensor in it runs great for about a thousand miles if it had a bad wire or a bad connector shouldn't it fail almost immediately? I do know that I had to order the delphi for the right side and the bosch was not side specific. I don't know if that matters or not.
Old Jul 1, 2010 | 05:09 PM
ChrisLT1conv
p.s. I get an h64 code each time it fails
Weav's Vet's Avatar
Weav's Vet
No, I meant the voltage to the O2 and the O2 plug, sorry.
Old Jul 1, 2010 | 05:21 PM
ChrisLT1conv
I'm not sure. I'll ask the mechanic to check it. What should it be?
Old Jul 1, 2010 | 05:24 PM
aklim's Avatar
aklim
IIRC, there are either 3 or 4 wires. 1 or 2 of them are ground. If it is a 3 wire, one is 12V, the other is ground and the other goes to the computer. If it is 4 wire, the same except one is ground.
To right o2 sensor keeps failing
Old Jul 1, 2010 | 05:43 PM
ChrisLT1conv
thankyou
Old Jul 1, 2010 | 09:52 PM
ChrisLT1conv
o2 sensor is changed. My car is running better than it has ever run with the bosch o2 sensors in it.
Old Jul 1, 2010 | 09:54 PM
Weav's Vet's Avatar
Weav's Vet
Good deal! Now let's hope it last a while!
