1986 ECM location
Old Jun 27, 2010 | 08:03 AM
rrwebster's Avatar
rrwebster
Default 1986 ECM location
Looks like it's right above the passenger side where the feet go. Thought I'd ask before tearing everything apart.
thanks in advance!
Robert
Old Jun 27, 2010 | 08:21 AM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
thanks in advance!
Robert
That is where it is. Start by removing hush panel on pass. side. then look up. Are you getting a code?
Old Jun 27, 2010 | 08:24 AM
rrwebster's Avatar
rrwebster
Thank you!
Old Jun 27, 2010 | 10:14 AM
black88z51's Avatar
black88z51
don't forget to disconect the battery before touching it.
Old Jun 27, 2010 | 11:42 AM
Muffin's Avatar
Muffin
Unless you are small it may be worth removing the passenger seat to give you more room.
Old Jun 28, 2010 | 06:31 AM
rrwebster's Avatar
rrwebster
thanks guys.... what checking to see if I needed a hot chip... it already had one... a hypertech.... I'm not small but flexible... I've also got a 944 Porsche so tight quarters I am used to.
thanks again,
Robert
Old Jun 29, 2010 | 01:53 PM
azrocketman's Avatar
azrocketman
I'm still getting an intermittent code 24 (Vehicle Speed Sensor) on my '86. The light comes on whenever it likes, typically when I'm just cruising with no significant throttle or just after I've backed off on the throttle. I've replaced the VSS on the transmission and reseated the connectors on the dash electronics. I'm not small so I'm guessing that I need to improve my gymnastics routine to check the connectors on the ECM.
Steve
Old Mar 25, 2019 | 05:03 PM
weightlossstar's Avatar
weightlossstar
Cruising
Going to try using a mirror 1st on my 86L, before pulling the seat and since this is my first time removing the ECM I hope it makes it easier then can do it by feel- it is now March 25, 2019 my how time passes. UPDATE: The mirror & flashlight work fine THE MOST IMPORTANT THING TO DO . . .IS to reinstall without the connections plugged in, makes the job simple and you won't jam up your
temperature control cable (a rookie mistake)
Old Sep 12, 2020 | 07:22 AM
Marauderprime's Avatar
Marauderprime
Did it fix your VSS code issue?
To 1986 ECM location
