super t-10 seals
Old Jun 29, 2010 | 11:01 PM
hughesm's Avatar
hughesm
Default super t-10 seals
me shifter linkage seals are leaking,all three,i have a 1988 4+3 super t-10 transmission.any body ever change these seals.i am no mechanic but i try to do all my own repairs.do i have to drop the transmission or can i do this without removing tranny.car has 90000 miles and run strong.any help would be appreciated.allready bought seals just need to get them in. thanks mike
Old Jul 1, 2010 | 08:11 PM
WVZR-1's Avatar
WVZR-1
You should have no trouble replacing the seals with the trans "in the car"! If you've purchased the correct seals you should be all set.
I don't recall the relationship of the shift shafts to a "full fill" so it might be wise to maybe remove some trans lube or check first the relationship. Maybe just service it while your there with a "fresh fill"!!
Old Jul 1, 2010 | 10:32 PM
rodj's Avatar
rodj
#74 in diagram
http://www.nastyz28.com/tech/bw-t10.html
To super t-10 seals
