Any tricks to remove oil filter
Old Jul 1, 2010 | 08:28 PM
Cyclonite's Avatar
Cyclonite
Somewhere, years ago I bought an oil filter wrench that has 3 'fingers' that is used with a ratchet. The fingers are cammed and decrease in size (grip tighter) upon counter-clockwise torque application. This thing has served me for half a dozen (at least) vehicles over the the past many years.
It's easier than the strap-type wrenches because it's straight access over the end of the can, and you can attach an extension to the ratchet if needed, and have room to actually turn the wrench!
Old Jul 1, 2010 | 08:33 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Originally Posted by WW7
If all else fails I have resorted to pushing a screwdriver through the filter so I could turn it....... Hey, it works ...WW
The last time I tried that on a stuck filter, the case & filter media came off but the filter base stayed tightly stuck to the engine. Had to get the car towed& put on a lift, where they used an air chisel to break the base loose----Damn Fram filters----
Old Jul 1, 2010 | 09:13 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
I always use an old screwdriver. It is a mess even with the proper wrench.
Old Jul 1, 2010 | 09:38 PM
slickfx3's Avatar
slickfx3
moral of the story?
snug, it won't leak, and so what if it does, never has on me
EZ does it
Old Jul 2, 2010 | 08:43 AM
Red Guts's Avatar
Red Guts
This hasn't failed me yet...
Old Jul 2, 2010 | 02:58 PM
samsonb's Avatar
samsonb
I didn't have a mess. What you do is get something like this:
They sell different ones, so you have to match it up to what filter you use.
Then just break the filter loose. Then set your drain pan under the filter. I recommend the Wedco W77 drain pain. Then take a poker and push into the bottom of the oil filter to poke a hole. And let it drain for a little bit. Then finish unscrewing the filter by hand and set filter in the drain pan. No mess.
Old Jul 2, 2010 | 03:04 PM
Pete K's Avatar
Pete K
Originally Posted by rayman300
Just trying first oil change on 95 vette and can not seem to remove the oil filter. If any one knows of an idea I would be very thankful.
Just about any type of oil filter wrench works well. What kind were you using?
Old Jul 2, 2010 | 03:28 PM
slickfx3's Avatar
slickfx3
an oil filter is an oil filter for the most part, it not an upside-down late model Mercedes or something like that,
Old Jul 2, 2010 | 04:43 PM
samsonb's Avatar
samsonb
Yeah, I never got the upside down oil filter positions. I bet those make a mess when you pull them? I believe the ZR1 oil filter is upside down as well.
Old Jul 2, 2010 | 04:49 PM
aboatguy's Avatar
aboatguy
On my 95 Vette I use my HAND....
Sometimes if the filter is really hot I wrap a rag around it and then use my hand...
I have two sizes of the bottom off the filter adapters and a couple of other filter wrenches but 99.2% of the time my hand or hand and rag methods work.
The upside down filters on the BMWs are pretty easy to do too....
On a C4 I don't see the point of putting a hole in the filter...
But what do I know I've been working on cars since the late 1970s and have never paid for an oil change....
Mike
once again it looks like a little time in the weight room would alleviate a lot of trouble....
Old Jul 2, 2010 | 05:01 PM
94z07fx3's Avatar
94z07fx3
It made since on the Jeep. I wouldn't want to be on some trail and knock the thing off.
I do have a motorcycle where the shop manual calls for the new filter to be put on hand tight and then turned a full turn with the filter wrench. I suppose my version of hand tight is a bit further than theirs because I've only ever felt safe turning it a half turn at most with the wrench after I've gotten it as tight as I can by hand.
Of course, fresh oil on the threads and seal help them go on without messing up the seal.
Old Jul 2, 2010 | 05:04 PM
Pete K's Avatar
Pete K
True story. I had a friend that was about 5'8" and weighed in at 110 pounds. He was so skinny, he looked starved.
He would not work on his car when I watched him, and I could never figure out why. Turns out, no strength. He would tighten a sparkplug by hand, then slip a 9 inch piece of pipe over the ratchet handle so he could torque the plug.
Old Jul 2, 2010 | 06:47 PM
  #33
WW7's Avatar
WW7
Here's another trick for getting off a tight filter... Take a piece of sandpaper, any grit, fold it in half, then use it to loosen the filter..Most times the filter won't come off by hand because you can't get a good grip on it. Using the sandpaper lets you use all your strenght to turn the filter instead of using your strength to try to grip it..Im serious try this it really works.. Its the same principle as those rubber pads they use to open jars.....WW
Old Jul 2, 2010 | 07:52 PM
  #34
samsonb's Avatar
samsonb
With that method, next time you could put on a Purolater Pure One oil filter as it already has that sand paper coating on the case.
Old Jul 2, 2010 | 08:15 PM
  #35
kenv's Avatar
kenv
St. Jude Donor '10
Depends on the car. I bought one of those (in red), but it won`t work on my `06 Milan. Can`t get the angle on the dangle
Old Jul 2, 2010 | 08:19 PM
  #36
kenv's Avatar
kenv
St. Jude Donor '10
moral of the story?
EZ does it
I now know (from experience) that this is the best advice
Old Jul 2, 2010 | 09:08 PM
  #37
ex-x-fire's Avatar
ex-x-fire
If you ever find yourself w/ a filter that's torn down to nothing, you can use a 1/2'' allen socket to loosen the base. If you look inside the threaded stud of the filter mount you'll see the allen. Then remove whats left over, then screw the stud back in. I'd do this before any air hammerin'.
To Any tricks to remove oil filter
Old Jul 2, 2010 | 09:15 PM
  #38
WW7's Avatar
WW7
I know , thats the filter I use but most don't have a textured surface..WW
Old Jul 2, 2010 | 10:03 PM
  #39
samsonb's Avatar
samsonb
I know , that the filter I use but most don't have a textured surface..WW
I've used that filter before. Last time I went with Napa Gold. With the filter wrench adapter thing, it's no problem removing and installing a filter. You'll have the wrench out anyways for the drain plug.
Old Jul 2, 2010 | 10:07 PM
  #40
NocarbutaVetteforme's Avatar
NocarbutaVetteforme
It has gotten to the point that I use this every time I change the oil filter. I just make sure to not over tighten when I put it back on.
