clutch slave cylinder
Old Jul 2, 2010 | 06:09 PM
mavidatt's Avatar
mavidatt
Default clutch slave cylinder
Hey how hard is it to replace the slave cylinder to clutch on an 89 corvette, never done this before and was looking to save some money if it is not that hard. Mechanic told me he thought it was the slave cylinder, the clutch engages way to fast and the pedal makes a squeeking noise and is not very consistent. Any help appreciated, thanks.
Old Jul 2, 2010 | 06:51 PM
MK 82's Avatar
MK 82
An average mechanic can do it. There are numerous threads here on how to bleed it. I can be a bit tricky as they put the bleeder on the bottom. Go figure!
Old Jul 2, 2010 | 10:57 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
I think the average backyard mechanic can do it too. If you understand how to bleed brakes, you can do it. In some ways, should be easier than brakes.
There are a couple of good threads posted this year. Look for "Slave cylinder" in the title and see if you can find them. The best one was posted in C4General with lots of pics.
Old Jul 2, 2010 | 11:10 PM
jhammons01's Avatar
jhammons01
I was afraid of this task...but once I got the car up in the air for the first time.....I saw that the thing was right there....two 15 mm bolts hold it in place....you'll need a swivel and an extension for your socket set......that is all.
Engages way too fast.....hrmmm...you mean the pedal is working too good? As soon as you push the pedal a few inches the clutch slips??
Does your clutch slip in 4th or in your case 6th on the highway??
Old Jul 3, 2010 | 01:16 AM
GREGGPENN's Avatar
GREGGPENN
When he's talking about engaging, that refers to how much travel is necessary as the pedal is released from the floor! When you press the clutch, it DISENGAGES.
Reduced travel up from the floor would imply the system has air, or is going bad, or both.
Old Jul 3, 2010 | 01:51 AM
jhammons01's Avatar
jhammons01
^^Got it.....
Yes if it is engaging when your pedal is close to the floor....that is bad....but I wouldn't blame the slave as much as a worn clutch....
Old Jul 3, 2010 | 12:44 PM
856SPEED's Avatar
856SPEED
^^Got it.....
On these cars (C4 hydraulic clutch systems)......worn clutches will behave a little differently......these cars (manual equipped) are notorious for slave cylinder problems and when they go out, they leak fluid, causing air pockets, and the most common symptom is the "quick grap" of the clutch with a very short travel of the clutch pedal from the floor.....very short travel!......if the master cylinder has little or no fluid, if you fill it up, pump the clutch pedal until you have a clutch pedal again, then it is OK for a while, then you have a bad slave......only a short window bofore there is no clutch at all! been there done that recently!
Old Jul 3, 2010 | 03:50 PM
mavidatt's Avatar
mavidatt
exactly thats what is up, the so called "quick grab" it grabs way to quick when easing off the clutch pedal
Old Oct 21, 2011 | 04:56 PM
Waspination's Avatar
Waspination
What if you have a really late grab, near the top of the pedal travel?
Old Oct 21, 2011 | 08:07 PM
GREGGPENN's Avatar
GREGGPENN
That's where it's supposed to engage.
Old Nov 22, 2012 | 09:31 PM
armyreddevil7's Avatar
armyreddevil7
6th Gear
Default my clutch pedal is sticking
Not sure if this is the right place to post this, but my clutch pedal keeps sticking,I've changed the fluid twice and it helped, but now it sticks every time i drive the car...any ideas ? slave cylinder ?
Old Nov 22, 2012 | 09:45 PM
jhammons01's Avatar
jhammons01
^^You should start a new thread with that question as the topic...
Old Nov 24, 2012 | 02:30 PM
Old Ben's Avatar
Old Ben
2017 C6 of Year Finalist
Both should start anew. This thread is over a year old.
To clutch slave cylinder
