RE: Rear Wheel
Old Jul 2, 2010 | 09:38 PM
sunnfish's Avatar
sunnfish
Default RE: Rear Wheel
I noticed my right wheel tips in at the top when I go in reverse. Then when I go forward it looks straight agian. I had it up in the air and tried to find something loose and everything seems good. I would like to know if anybody has this problem?
Old Jul 2, 2010 | 09:41 PM
jhammons01's Avatar
jhammons01
the answer is found on the first page......look for another thread that contains something about the rear wheel falling.....
Old Jul 4, 2010 | 07:40 AM
sunnfish's Avatar
sunnfish
Thanks for the info. His problem is not the same. My wheel only tips in on the top when I go in reverse. When I go forward the wheel looks striaght. I will look at the camber bolt I do have it marked and it don't move. Just wondering if anybody else have any suggestions.
Old Jul 4, 2010 | 10:22 AM
jhammons01's Avatar
jhammons01
There are only a few connection points for the rear wheel "knuckle" to attach to the car.
Two Dogbones
the rear spring
The camber rod
and the half shaft
maybe one more......it's 7:00 am on a Sunday for me ...
Old Jul 4, 2010 | 04:18 PM
samsonb's Avatar
samsonb
Two Dogbones
the rear spring
The camber rod
and the half shaft
Tie rod.
Old Jul 5, 2010 | 12:38 AM
383vett's Avatar
383vett
Just wondering. How can you notice which way your rear wheel tips when you are going forward or backwards?
Old Jul 5, 2010 | 12:44 AM
Wiot's Avatar
Wiot
Ah, yep. I was wondering the same thing. I'm sure you've got a great answer, but that's also a great question.
Old Jul 5, 2010 | 01:41 PM
sunnfish's Avatar
sunnfish
not real hard. You back up then you get out and look. Then you go foward and get out and look. I hope that helps you maybe you can check yours out now!!!!
Old Jul 5, 2010 | 04:50 PM
darkstallion_69's Avatar
darkstallion_69
orrrrrr you can open the door and look while you go forward and back...
To RE: Rear Wheel
