Corvette Problems
Old Jul 3, 2010 | 12:34 PM
1986 4+3 CORVETTE's Avatar
1986 4+3 CORVETTE
Default Corvette Problems
So i got my exhaust installed and just for labor it was 1000$ and it was quoted at 500$ for hedders and an h pipe just had to vent a little bit, but any ways sometimes in my car when i get on the throttle my car will completely cut out it wont even bog. It will go to around 2000rpm and just cut out, everything else works fine does anyone know what it could be.
Old Jul 3, 2010 | 12:48 PM
Jamesnns's Avatar
Jamesnns
Did they buy you dinner first?
Geez.
Old Jul 3, 2010 | 12:53 PM
Pete K's Avatar
Pete K
If this has happened immediately after the exhaust install, I would think the first people to ask are the shop owners that gouged your wallet.
If this has happened well after the exhaust was installed (and drove normally immediately after the install) you need to be more specific.
Have you done the basics?
Fuel pressure check?
Timing check?
Checked vacuum with a vacuum guage?
Do a visual inspection to see if any sensor is unplugged? i.e maf sensor, cts etc
Check engine light?
If so scan for codes? If yes, what codes?
Help us help you.
Old Jul 3, 2010 | 01:24 PM
1986 4+3 CORVETTE
i havent done all the simple stuff yet and my car did this before the exhaust
Old Jul 3, 2010 | 01:29 PM
Pete K's Avatar
Pete K
Did the exhaust make it better? Or worse?
Old Jul 3, 2010 | 01:34 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
How much gas do you have in the tank when this happens. Hint, has this ever happened when you have over a 1/2 tank?
Old Jul 7, 2010 | 01:55 AM
1986 4+3 CORVETTE
It doesn't happen when I have a half tank or more
Old Jul 7, 2010 | 02:26 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Typical of the C4's is the fuel pump sucking air when the fuel level is less than half full.
Old Jul 7, 2010 | 11:43 AM
vader86's Avatar
vader86
Sounds like the fuel pump.
First I want you to go buy a fuel pressure gauge and hook it up at the rail, and watch the pressure readings on startup, while youre grabbing the throttle lever through the RPM range and then after shutting the car off. That will help us diagnose the problem (s).
And DO IT without taking the car to someone and telling them its the fuel pump so you dont get raped again.
Old Jul 7, 2010 | 02:27 PM
jimmers's Avatar
jimmers
If you were quoted $500 why did you pay $1000?
Old Jul 7, 2010 | 03:29 PM
jnealg's Avatar
jnealg
with all the above points. damn that shop saw a kid in a vette and brought out the lube!
Old Jul 8, 2010 | 01:47 AM
1986 4+3 CORVETTE
There were two corvette shops in auburn on the same street with mechanis named Dan. I got a quote from the 500$ place and accidently went to the other one. How lucky am I
Old Jul 8, 2010 | 08:47 AM
BADDUCK's Avatar
BADDUCK
Damn! Well I guess guess you deserved it.:
Not sure I would have told that.
Old Jul 8, 2010 | 11:30 AM
jhammons01's Avatar
jhammons01
Damn...for $1000....or $500 I would have done it.....Maybe I would have done it for $250....
To Corvette Problems
