84 crossfire starts, won't run
Old Jul 4, 2010 | 11:34 AM
daveandrew's Avatar
daveandrew
6th Gear
Default 84 crossfire starts, won't run
My wife and I just saved a 84 vette from the crusher...We bought it from a junk yard and have started to restore some of it. The motor cranks and fires but won't run as we were told it did.Does anyone have a detailed trouble shooting method? I am an old mechanic but I know very little about fuel injection. We would love to hear from someone who has been thru this. Thankyou.
Old Jul 4, 2010 | 11:56 AM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Check for fuel and spark. Check fuel pressure. Pull a plug and see if you are fetting good spark. Any codes?
Old Jul 4, 2010 | 12:38 PM
94z07fx3's Avatar
94z07fx3
Will it briefly run on starter spray?
Old Jul 4, 2010 | 12:40 PM
CorvetteMike2024
Corvette Enthusiast
Good point.
Old Jul 4, 2010 | 02:10 PM
Trog's Avatar
Trog
with air cleaner off you can see the injectors spraying down onto the throttle plate easily. Does it stop flowing? I will have to check my FSM but it may give fuel for start but if the oil pressure doesn't come up it cuts fuel to "save" the motor. I know later TPI systems have that feature.
Old Jul 4, 2010 | 02:28 PM
jhammons01's Avatar
jhammons01
If you get initial fuel pressure from the pump.....then it squirts a few times and the pressure bleeds off due to a semi clogged filter or a weak pump or clogged pick up sock.....the available pressure to the injectors drops below the minimum level and they stop squirting........motor dies....
If you are restoring the car.......Go ahead and buy an '85 (Stronger) fuel pump and a new fuel filter....swap it all out and see what you get.....
I guess I should recommend (first) that you hook a fuel pressure gauge and see what it drops to on that initial fire.......
Old Jul 4, 2010 | 02:46 PM
94z07fx3's Avatar
94z07fx3
I know you are trying to help out one of our Corvette brothers which is a great service. However, you have been mis-informed. Please don't spread this busted myth. Thanks
Old Jul 4, 2010 | 03:35 PM
daveandrew's Avatar
daveandrew
6th Gear
Wow you guys have some great ideas. I will have to borrow or buy a pressure guage and see how much pressure I have. Thank you all for the help. I will get back with you when I know more... happy 4th of july all!!!
Old Jul 4, 2010 | 06:52 PM
jhammons01's Avatar
jhammons01
Oh no he di'int.....
From the other thread I am involved in....Now you "have an ax to grind"....LOL
Hey quit "stopping" the fun myths......this is the innerweb
Old Jul 4, 2010 | 07:23 PM
94z07fx3's Avatar
94z07fx3
Can't be me. My axe has an "e".
Old Jul 5, 2010 | 12:04 PM
jhammons01's Avatar
jhammons01
Notice the quote?? LOL...mine usually contains one as well
Old Jul 5, 2010 | 01:17 PM
cumbercr's Avatar
cumbercr
How a message is delivered is usually more important than the message itself. A courteous correction is much more likely to be listened to.
To 84 crossfire starts, won't run
