headlight motor problem
Old Jul 4, 2010 | 07:03 PM
klug932000's Avatar
klug932000
Default headlight motor problem
i have the assembly apart (drivers side) on a 85 because the light would not turn up. when i have the wire clip off the adjuster the motor turns fine, but when there is pressure on the **** it starts to short, the motor turns even when the headlight switch is off. any ideas, what are the parts needed to rebuild the motor?
Old Jul 5, 2010 | 08:36 AM
HlhnEast's Avatar
HlhnEast
If I understand correctly the motor shuts off because of torque created when the light bucket comes closed or open all the way. The mechanism that does this is at the bottom where the manual **** comes thru. The spring there actuates contactors that turn the motor off. I dont have the knowledge to explain it further but if these contactors are worn or dirty, the motor wont work.
Good luck!
Old Jul 5, 2010 | 04:52 PM
klug932000's Avatar
klug932000
Is the shaft from the manual control **** into the motor one piece or two?
Old Jul 5, 2010 | 05:01 PM
Batman0913's Avatar
Batman0913
Ive had the same problem try this...?
On the left headlight connect the positive wire to the green wire from the motor and to open, connect the negative to the white wire. These are the wire colors on my 84 and I am assuming they are the same on yours . If the headlight opens, you have one or more defective headlight relays. Good Luck.
Old Jul 5, 2010 | 09:55 PM
klug932000's Avatar
klug932000
thanks for the reply, yes the wires are the same, when i tried what you said it made a squeaking noise, and when the clip was off the **** moved slightly. any more ideas?
Thanks Pat
Old Jul 5, 2010 | 09:59 PM
klug932000's Avatar
klug932000
does anyone have a breakdown of this motor?
Old Jul 5, 2010 | 10:41 PM
Batman0913's Avatar
Batman0913
I had the same problem you did. Mine did the same thing. I just got a new motor....!
Glad I could help...!
Old Jul 5, 2010 | 11:28 PM
klug932000's Avatar
klug932000
can/or where did you get just the motor?, ecklers only has the whole unit
Old Jul 6, 2010 | 03:05 AM
Hot Rod Roy's Avatar
Hot Rod Roy
You may not need a new motor. Try taking it apart and cleaning the limit switch contacts at each end of the motor, and with a good clean-up and lube with white grease (Lubriplate or equiv.) you'll probably be good. I had the same problem with my '84 before my clean-up job. They've been working good for a couple of years since I cleaned mine.
Old Jul 6, 2010 | 10:16 AM
klug932000's Avatar
klug932000
ill give her a try, im going on vacation and wont have internet access until Saturday ill let you know how it goes when i get back
To headlight motor problem
