Left rear wheel clicking
Old Jul 5, 2010 | 02:39 PM
Jamie Lennartson's Avatar
Jamie Lennartson
Default Left rear wheel clicking
Was doing some quick driveing thru the mountains today and my left rear wheel started makeing a very heavy clicking sound like there was a big rock in the tire.
Every time i turn it to the left it gets louder im i right to guess a bad wheel bearing?
Old Jul 5, 2010 | 02:42 PM
Pete K's Avatar
Pete K
Yup. Jack it up and wiggle it to check.
Old Jul 5, 2010 | 02:47 PM
Jamie Lennartson
Do they sell the bearing because ive been checking and only finding whole
Rear Hub and Bearing Assembly's?
Old Jul 5, 2010 | 03:08 PM
Pete K's Avatar
Pete K
Sealed is the only way they are sold. Diagnose, then purchase.
If shot, be prepared to buy both sides. They wear out together.
Old Jul 5, 2010 | 04:23 PM
WW7's Avatar
WW7
And don't forget to go to the chevy dealership and get the 2 teflon washers that go in each side or you will be tearing it apart again real soon...WW
Old Jul 5, 2010 | 04:34 PM
samsonb's Avatar
samsonb
You could look at a WBI bearing hub from Summit. It is USA made with *** bearings.
Old Jul 5, 2010 | 04:40 PM
94z07fx3's Avatar
94z07fx3
Hub Assembly – Rear Suspension Hub Assembly, Rear Suspension, 1984-1996 (GTG0501) GM #7470501
Teflon-coated washer. GM #14076924 (WW7 )
36 MM. Deep well impact 1/2” drive socket
Torx T55 - 3/8” drive socket
BTW The FSM specs a certain GM goo for the wheel speed sensor. I used a smack of common blue RTV no troubles.
Old Jul 5, 2010 | 04:52 PM
samsonb's Avatar
samsonb
So, you're supposed to seal that sensor when you bolt it back on? I just cleaned it up and bolted it back on without any goo. Nobody must be putting any sealant on since I've never read anything about it in the writeups on replacing a rear hub.
Old Jul 5, 2010 | 04:55 PM
94z07fx3's Avatar
94z07fx3
Two thoughts: It isn't critical. GM writes manuals and proceedures that must cover a wide range of geography and driving conditions.
Maybe it's a road salt thing? Maybe it's a vibration thing? I don't know.
EDIT:
Ok so I looked it up.
94 FSM 5E2-144
Notice: ... Wheel speed sensors must be given an anti-corrosion coating before installation to prevent galvanic corrosion. Do Not use grease. Use sealer, GM P/N 12345489 or equivalent.
Old Jul 5, 2010 | 05:15 PM
samsonb's Avatar
samsonb
EDIT:
Thanks. That's good to know. I did wonder what that yellow gunk was around the sensors.
Old Jul 5, 2010 | 05:38 PM
94z07fx3's Avatar
94z07fx3
OP: Do you have the backoff protector and its cotter key installed?
Old Jul 5, 2010 | 06:29 PM
Jamie Lennartson
Yes the vid was just me getting it tight.
Old Jul 5, 2010 | 06:44 PM
94z07fx3's Avatar
94z07fx3
Certainly I hope you've got a solid fix that will last years and years. However, I am puzzled as to why it went from no clicks to clicks that were caused by the axel nut being backed off while the nut was protected from backoff.
IMHO, keep an eye on it and if it exhibts symptoms again at least tear into it and eyeball everything.
Congrats on the fix and good luck!
BTW I bought my last bearings at O'Reily's for <$90
Old Jul 5, 2010 | 06:53 PM
samsonb's Avatar
samsonb
When I did mine. I made sure to torque that nut down. I believe the spec is around 166 ft/lbs. But I went to 185 ft/lbs. Some guys torque theirs to 200 ft/lbs. They say the book says to torque it with the wheel off the ground.
I also used a large cotter pin and made sure that retainer was on there tight. As I noticed one of the retainers was loose as that is the side the PO had ujoints replaced. I figure if the retainer is on there loose, then it can/will let the nut back off.
Old Jul 5, 2010 | 08:44 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Sorry to tell you but you probably just masked your bearing problem.
Since I've had 2 fail on my 92 I'll bet the loose axle nut was symptomatic of a seperated bearing.
First one I pulled the nut off and the hub came off in two pieces.
Second one the inner race came apart.
Good luck, keep a good eye on it.
Old Jul 5, 2010 | 09:32 PM
94vettelover2's Avatar
94vettelover2
Normally when those nuts get loose its because the bearing is bad & has excessive play/movement.I bet that soon you will have the same problem again.Sorry for being negitive,just speaking from experience
Old Jul 6, 2010 | 12:20 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Those vice grips are no way close to the torque required for that nut.
There, 164 ft lbs are required.
To Left rear wheel clicking
Old Jul 6, 2010 | 05:39 PM
Jamie Lennartson
I locked the vice grips then got a wrench on it and TQ it down as hard as i could.
Old Jul 6, 2010 | 05:49 PM
floridamale's Avatar
floridamale
Come on Hokies go by a 36mm 1/2 inch drive socket & breaker bar and do the job right.
I will say if I found that on my car I would remove the hub for an inspection rather then just tighten the nut and keep driving on it.
Old Jul 6, 2010 | 06:21 PM
Jamie Lennartson
We checked the bearings and they all seemed just fine.
