Where to install MSD Box/Coil Blaster/Map Sensor.
Old Jul 12, 2010 | 09:04 AM
LD85's Avatar
LD85
I have info so anyone can email me if you are interested
Old Jul 12, 2010 | 09:48 AM
88BlackZ-51's Avatar
88BlackZ-51
Larry. This is where I installed my coil.
Given the pictures. Is that bolt in the same location as yours? If so the bracket should work correct?
Old Jul 12, 2010 | 09:53 AM
LD85's Avatar
LD85
The coil mount looks good and the bolt for the MSD bracket is the same as mine.
Old Jul 12, 2010 | 10:41 AM
88BlackZ-51
Thanks.
Old Jul 22, 2010 | 04:53 PM
LD85's Avatar
LD85
Got a couple of brackets, pm me if you are interested
Old Jul 22, 2010 | 09:43 PM
88BlackZ-51
I ordered one guys!
Old Jul 22, 2010 | 09:54 PM
fc_soldier's Avatar
fc_soldier
I put my box under my passenger seat, controlled enviroment.
Old Aug 13, 2010 | 11:24 AM
88BlackZ-51
Well the bracket showed up, and it looks pretty good.
It fit pretty much perfect except I had to shave the one corner as it was catching on a part of the hood. The pictures will explain. I have to go out today and buy a Kobalt stainless steel bit. I tryed a few of my metal bits, and I was sweating like a ***** trying to drill the holes to hold the MSD in place.
Stainless Steel is tough chit!
Thanks LD.
Old Aug 13, 2010 | 02:23 PM
LD85's Avatar
LD85
Use a center drill!
Old Aug 13, 2010 | 02:47 PM
88BlackZ-51
Use a center drill!
Bought some bits for SS today. Pricey little one's....
