A/C Problems
Old Jul 7, 2010 | 08:23 PM
Tom's '07 Monty's Avatar
Tom's '07 Monty
Default A/C Problems
I have a 90 Roadster that does not seem to cool properly. It has proper load of freon. In the 90+ degrees in North Texas, it does not cool the car. I can feel cool air (not real cold) coming out of the vents. Also, even though the blower is set at 10, the air flow is not very strong. Any suggestions?
thanks, Tom's '07 Monty
Old Jul 7, 2010 | 08:24 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Check your blend door for proper movement.
Old Jul 7, 2010 | 08:28 PM
Tom's '07 Monty
good idea! Had that problem in my '78 - it had a pinched vacuum line to the motor that opened the door (came that way from the factory).
But that does not account for the low blower speed.
thanks
Old Jul 7, 2010 | 08:39 PM
CorvetteMike2024
Corvette Enthusiast
thanks
The blower speed on these C4's is very pathetic at best. Agent 86 knows alot about the HVAC controls. Maybe send him a PM. I think the high speed on the fan may be controlled different than lower blower settings.
The blend door is electronically controlled.
Old Jul 28, 2010 | 06:51 PM
Bubba91's Avatar
Bubba91
How do you check the blend door?
I also have low air flow and I just cleaned my evaporator and condenser. Mine is a 91 with manual controls, r134a and the temp from the vent is only 70 degrees and it has a full charge. thanks
To A/C Problems
