Wow !! this place is full of Dumb!!! shade-tree ideas I'm afraid to speak..
Do what the F**k you want with your cars they are yours to screw up as you please
Then GM screwed them up from birth.
I do agree this in a million years doesn't sound like good advice, adding bars leak pellets to a cooling system, but I think it reflects that all is not picture perfect in a brand new car when it comes off the assembly line.
Dissimilar metals, porous castings, and loose manufacturing tolerances contribute to having the need for such items like pellets.
You'd be surprised what is done at the factory level. Both good and bad.
My favorite "cover your ***" TSB came from Chevrolet, in 1955, when the first small block 265 V8's had warranty issues over piston rings not seating... they recommended the dealer mechanics to dump bon-ami scouring powder down the carb while running lol.
Rob
GM - by Service Bulletin - denies dumping anything in on the Line so I don't know where some of this is coming from.
It's right in my 1994 FSM under coolant refill procedures. Pg. 6B-16
"DRAINING AND FILLING THE COOLING SYSTEM
Every 12 months or 15,000 miles whichever first occurs, the items listed under the Maintenance Recommendations" should be serviced.
Every two years or 30,000 miles whichever first occurs, the cooling system should be drained and filled using the following recommended procedures:
1...
11. after 4 minutes of engine operation or once the level of water/coolant mixture is maintained at the base of the neck of the radiator surge tank (whichever occurs first), turn the engine "OFF", add 6 cooling system sealer pellets, GM P/N 3634621 (VIN P only) through opening in the radiator surge tank and install the radiator fill cap on the radiator surge tank making certain the arrows line up with the overflow tube."
So does mine - Bulletin followed. GM doesn't even run Coolant through the Intake anymore which was the area of most leaks - though they've had a hell of time with some of the composites; especially on the sixes.
As stated, many GM cars came from the factory with them, and have instructions in the service manual to add them.
If you have a leak, it's true this may not be the way to fix it. But the pellets themselves when used in a proper amount, pose little risk to anything. They are mostly walnut shell. They will not corrode anything, they don't sludge, and supposedly they can help keep the water pump cleaner by "scrubbing" it.
I've put coolant pellets in our Buick as recommended by the manual at every coolant change. The car has 222,000 miles on it and no problems other than a small oil pan leak and a bit of a grumble from the supercharger.
That said, I do not believe Corvette's recommend these pellets. Edit: I stand corrected on this part, someone posted their FSM recommendation.
If you use those pellets. I've read to crush them up before you put them in the radiator.
They dissolve pretty readily. The main thing is not to put them in a surge tank. There isn't much flow out of there and will probably just crap it up (as the ratio of pellet to liquid is so high).
