Puzzeler
Old Jul 10, 2010 | 05:21 PM
Casket86's Avatar
Casket86
Default Puzzeler
Okay, here we go. 1986 L98
There was a bad rattle in the area of the AC whenever the AC was running (original compressor and clutch btw) so I swaped out the compressor, recharged etc. There was still a rattle after all was done. The mechanic who recharged my system for me bet me a beer it was the belt tensioner, so I swapped that out. Sonofabuck owes me a beer. The rattle remains, but only when the AC is on. I suppose it is possible that I have another bad tensioner, but I figured I would check for any input before I go further. Just looking for other possibilities.
Casket
Old Jul 10, 2010 | 06:25 PM
Casket86's Avatar
Casket86
ttt
Old Jul 10, 2010 | 08:16 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Do you still have the frisbee on? Its designed to smooth out belt when AC is on.
Old Jul 10, 2010 | 09:09 PM
Casket86's Avatar
Casket86
I am still a novice, but did the 86 come with a frisbee? I never removed one, and have not seen one either. I purchased this car last fall. This is really the first trouble spot I have had. I just replaced the belt as well, and it is still a little noisy. Guessing it is either this frisbee issue, or a bad from the box tensioner.
Old Jul 10, 2010 | 09:37 PM
CorvetteMike2024
Corvette Enthusiast
I dont know if the frisbee was on your year model. The frisbee is a nickname for a large circular metal disk that runs on the front of the water pump to minimize belt movement when AC is on
Old Jul 10, 2010 | 10:20 PM
blown1981z28's Avatar
blown1981z28
Did you replace the belt also? My 87 made a rattle only with the AC on also. The tensioner was bouncing off it stop. A new tensioner and belt fixed it.
Old Jul 10, 2010 | 10:36 PM
Casket86's Avatar
Casket86
Yep, did the belt too. The rattle is not nearly as bad with the new belt and tensioner and is now only present at idle. The slightes increase in rpms and it goes away as the tensioner becomes more static. At idle the new tensioner tends to want to bounce. I am thinking that my new tensioner may be bad. I did notice some scratches on top of the pulley arm right out of the box. Makes me think that this particular unit has been installed and returned before. I am gonna have them order up a replacement. I need to get this fixed asap as we are heading out to the Black Hills Corvette Classic in Spearfish South Dakota on Wednesday. God I can't wait. And yes, I know......pictures. Lots and lots of pictures. Thanks for the input thus far, and any more that may be forthcoming.
Old Jul 10, 2010 | 10:49 PM
Casket86's Avatar
Casket86
Do you recall what brand tensioner you used? I see that O'reilys has Gates ($95.99) or Dorman ($58.99). The one that I put on was a gates (I ordered over the phone, bastards never said anything about a cheaper one).
Old Jul 10, 2010 | 11:47 PM
JW3101's Avatar
JW3101
St. Jude Donor '11-'12-'13-'14-'15-'16-‘17-‘18
'86 didn't have a frisbee.
Old Jul 11, 2010 | 12:24 AM
chileverde's Avatar
chileverde
If the tensioner is bouncing around when the car is idling with the AC on, then compare with the AC off.
If the tensioner movement is considerably more violent when the AC is on, see if the car's idle speed is staying within specs. The idle speed itself might be too low.
Rob
Old Jul 11, 2010 | 01:35 AM
Casket86's Avatar
Casket86
Idle speed is at 600 rpm
Old Jul 11, 2010 | 02:05 AM
chileverde's Avatar
chileverde
i don't know what idle speed spec is for your year, but try setting it a bit higher (750rpm) and see how that works out.
rob
Old Jul 11, 2010 | 10:53 AM
Casket86's Avatar
Casket86
rob
Temporarily adjusted Idle speed to 800. Does not chatter as bad, but still there. O'Reileys will have a replacement for me by 4:30 today. I does not appear to be un-driveable as the belt is running true and in line. The chatter is just annoying as well as a little embarassing.
Thanks for all the good input.
Old Jul 11, 2010 | 11:27 AM
CorvetteMike2024
Corvette Enthusiast
I have a 89 FSM. In the future if you need any info out of it I can copy and post them up for you.
Old Jul 11, 2010 | 12:54 PM
chileverde's Avatar
chileverde
if the new tensioner doesn't rid you of the vibration...
changing out the alternator pulley to a decoupling style pulley will reduce torque strain on the belt system and should alleviate the tensioner rattle. it acts as a damper of sorts and reduces strain on the belt assembly.
the C5's got this as a fix for the same problem on A4 equipped models with customers complaining of the same issue.
info link: http://www.alternatordecoupler.net/f...itensOAD-2.pdf
the C5 pulley will fit the C4 alternator, and can be found on ebay for around 70 bux. the spline tool to install one is another 20.
rob
Old Jul 13, 2010 | 05:30 PM
Casket86's Avatar
Casket86
Just wanted to say thanks to all for the input.
Oddly enough (and I still can't believe this) the problem was an over filled ac system. The shop that charged my system put in a little too much. I guess the higher pressure works the motor just a little too hard? Anyway, the shop near where I work reduced the charge by a few pounds and the rattle is gone. I would not have believed it if I did not watch the whole process.
Thanks again all. This forum is fantastic when it comes to helping people out.
Old Jul 13, 2010 | 07:37 PM
chileverde's Avatar
chileverde
Cool to hear thats all it was - I knew the problem had to do with excessive torque on the serpentine belt, but wouldn't have guessed the compressor reacted that way to too much freon.
To Puzzeler
