Code 36 why me?
Old Jul 11, 2010 | 04:26 PM
rogerdoger1993's Avatar
rogerdoger1993
Default Code 36 why me?
I never got a check engine light. However, when I did the paper clip method it showed code 36. I noticed my car has been running slightly rough. It's a 93 LT1 Btw. And It recently started to give off a slight ping at lower RPM's under load. Could this be the dreaded OPTI issue? I hate my life.
Old Jul 11, 2010 | 04:40 PM
STL94LT1's Avatar
STL94LT1
Yep, that is an opti code. First off, pull the opti wire harness and check for corrosion.
Old Jul 11, 2010 | 06:14 PM
rogerdoger1993
Alright im gonna do that righ now.
Old Jul 11, 2010 | 10:08 PM
rogerdoger1993
I checked and no corrosion around the harness. Why do I have code 36 but never once got a check engine light?
Old Jul 11, 2010 | 10:46 PM
Mikes1991's Avatar
Mikes1991
Dude Id much rather have an Opti isssueright now than what Im doing. A tear down of the motor to fix a head gasket. I wish that was my only problem although I dont have an opti so that wont ever be a problem. Best of luck
Old Jul 12, 2010 | 07:36 AM
timmy 93's Avatar
timmy 93
Keep driving it and a check engine light will show up.Thats what happend to my 93 then you risk getting stranded.As stated things could be worse.Tim
Old Jul 12, 2010 | 11:08 AM
rogerdoger1993
So I decided to start my car at night and see what was happening underneath the hood. As my curiosity got the best of me, I noticed my plug wires were putting on a nice fireworks display for me. So I am gonna try plug wires first and see if my problems go away.
Old Jul 12, 2010 | 11:37 AM
pologreen1's Avatar
pologreen1
good luck
Old Jul 12, 2010 | 12:28 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Sounds like you'll wind up doing new plugs, wires, AND a new Opti...possibly a water pump install, too. I would considering all the labor tear-down time involved.
But at least it'll run like new money again once you get everything new in place and buttoned down.
Old Jul 12, 2010 | 04:40 PM
rogerdoger1993
Nope just wires. I already replaced the plugs last month.
To Code 36 why me?
