TB cable adjust made a difference...
Old Mar 23, 2002 | 07:45 PM
Lone Ranger's Avatar
Lone Ranger
Default TB cable adjust made a difference...
My throttle body butterflies weren't getting full open with the pedal to the floor! The control arm assembly for the butterflies lacked hitting the stop by maybe 3/8". Made the adjustment... there's a Sweet Spot to be found for sure. Best throttle range performance/response was found when the adjustment was such that with the pedal held to floor for WOT the butterfly arm assembly stop was held against the throttle body housing with a slight firmness, and not hammered hard-pressed against it. I don't know why this is, but my SOTP meter indicates this is the best tb cable setting for throttle response on my ride. :yesnod:
Old Mar 23, 2002 | 07:53 PM
MY 95's Avatar
MY 95
CI 2-3-4-5-6-8-9 Veteran
St. Jude Donor '05-'06-'07-'08
Default Re: TB cable adjust made a difference... (95_C4_convertible)
how did you know they werent opening, did you have it apart??
Old Mar 23, 2002 | 09:03 PM
Lone Ranger
Default Re: TB cable adjust made a difference... (My 95)
Butterfly arm wasn't making it to the stop. Runs better now, must have helped.
Old Mar 24, 2002 | 12:40 AM
EricVonHa's Avatar
EricVonHa
How did you adjust that bad boy?? I thought from the ASR to the TB that it was "non-adjustable".?? I'm guessing with the bracket that bolts to the side of the manifold, no? I'm curious... I've got a tough time making my TPS see the 4.0vdc for WOT... thanks.
Old Mar 24, 2002 | 01:05 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: TB cable adjust made a difference... (EricVonHa)
I think he means that the TV cable was keeping the throttle plates from opening fully. This cable has a tang that when depressed releases the cable so that the little nose piece in the front can be pulled forward. Usually if it's holding the throttle plates back just pressing the tang while holding the throttle full open will cause the TV cable to pull forward enough to let the throttle close fully.
If you're having getting the TPS over 4.5 Vdc at WOT try rocking the top of the unit about the lower bolt. Also you can set the base voltage to about 0.65Vdc before you cause the ECM to throw a code. This will show the ECM that the throttle is further open and move up on the fuel and timing curves.
Old Mar 24, 2002 | 01:54 AM
Lone Ranger
Default Re: TB cable adjust made a difference... (65Z01)
If you mean the TV cable that controls auto trans shifting, my '95 doesn't have a TV cable, the shifting is controlled by the pcm. Here's the cable routing on my '95: throttle cable comes out of the box on firewall and goes into the ASR unit which is mounted close to driver wheel well. 2nd cable then comes out of ASR then goes to ASR's diaphram unit which is what generates the pedal kickback impulse when ASR goes active. 3rd cable comes out of ASR about 8" then goes into a coupler which has a large square button in it with arrows pointing towards the ASR unit. Depressing this button allows adjustment of the section of the throttle cable which goes from the coupler, loops around, fastens to the driver side fuel rail cover, and finally connects to the throttle body butterfly arm/lever which opens and closes the throttle bodies. depressing the button on the coupler allows you to push the throttle cable either direction click by click to either put slack in it or take slack out.
I don't know how else to word it... I'm by no means an expert but this needed to be done on my car.
Old Mar 24, 2002 | 02:07 AM
Lone Ranger
See my othe reply above for the adjustment procedure. I may snag the digital camera from work tomorrow...er...look at the time... I mean later "today" and snap a photo of the coupler that is on my throttle cable when it exits the ASR on it's way to loop around onto the fuel rail cover. This coupler has a large plastic button on it with two arrows. Press this button and hold it and you can pull the throttle cable on the firewall side of the coupler out a click or two either direction towards the firewall or the ASR.
Now, how can you tell whether or not your Throttle Position Sensor is reading the movement correctly? I'm totally new at this.
Old Mar 24, 2002 | 02:25 AM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
________________________________________ _______________________________________
um i don't quite understand....can you please elaborate>....sorry Iam a bit slow when it comes to this type of stuff...if you could just put in into a little bit more laimans terms, that would be great.....
thanks jeff
Old Mar 24, 2002 | 02:32 AM
65Z01's Avatar
65Z01
95_C4_convertible, sorry for my ignorance on the differences from '88 to '95 but sounds like your TB cable adjustment has a similar effect on throttle closure as does my TV cable adjustment. Anyway, congrats on dealing with the issue successfully.
XtremeVette, the TPS on your '90 may not be adjustable. Mine has two slotted screw holes that allow me to adjust the base reading (with the IAC pintel fully extended, per directions on my site). I believe your TPS has two round mounting holes and so is not mechanically adjustable. Also your ECM may auto zero the TPS reading as your drive, whereas my ECM relies on the base reading being manually set. If someone else with a '90 or '91 L98 can jump in here it would be helpful.
[Modified by 65Z01, 12:37 AM 3/24/2002]
Old Mar 24, 2002 | 05:58 PM
Lone Ranger
Snapped a photo of the coupler that has the adjustment button on it:
[Modified by 95_C4_convertible, 3:59 PM 3/24/2002]
Old Mar 24, 2002 | 08:32 PM
EricVonHa's Avatar
EricVonHa
Thanks for posting the photo of the adjuster... I've always known that thing to be there, but never knew what the arrow was for. Now I know!!
I've replaced a couple gas pedals in my time of owning my LT-1... call it a case of the really serious "lead" foot. I'm thinking that through the geometry of the gas pedal possibly changing a hair and having the ASR system out multiple times to change plugs, headers, etc. that this has effected the(inefficient) operation of the throttle cable system. At WOT, my TPS will barely crest the 4vdc... 4.0x to be exact. 4vdc is all the ecm needs to see to signal wot... but it's a little close if you ask me. Also, on the LT-1, the TPS is non adjustable. Surely one could make it adjustable and monkey with it... but if the system is not showing over 4vdc at wot, it's indicative that there is something else wrong with the system.
So, thanks again for posting the picture along with the adjustment description procedure!! :cheers:
To TB cable adjust made a difference...
