It's getting close to putting the motor back in the frame and I wanted to install the intake on the block while it was on the stand. I figured I would make a plate with an eyelet on top and bolt this to the intake. Has anyone made there own lifting plate along the same principal as the "happy hooker" ? The only thing that scares me is the 4 small bolts in the aluminum intake holding the weight of a motor. Any thoughts or sugestions on this process? Thanks!
I had the Happy Hooker myself and I never used it.There is NO WAY Im going to let 4 small holes in a aluminum intake manifold hold the engine up.
I used the front and rear head accessory bolt holes to mount the chains.I ended up selling my hooker because as good as the idea is,Im not going to chance cracking the manifold bolts.
I don't undertand why folks get excited about lifting an LT1 with the happy hooker when folks have been using carb plates to lift big blocks for decades....
I've pulled my engine out numerous times with the hooker...(NO DRAMA) its a real time saver.
Is there a right way and a wrong to install the Hooker? I noticed that PLRX and fc_soldier have theirs mounted 180° out from aboatguy. I pulled mine like aboatguy. Does the orientation affect the angle? Mine came out pretty easy and I intended to re-install with it mounted the same way, just curious.
The happy hooker was designed to work for all LT1 motors. In a corvette it can be done either way. But in a camaro or firebird the motor is tucked under the body of the camaro/firebird alittle. So that hook design allows it to tuck under the lip and keep the motor somewhat level. And without damaging the body of the fbody.
I used some extra bolts and screwed them in the heads on diagonal sides, then used a chain. Since I had the stuff on hand it was free compared to buying a hooker. When you buy one does it say happy hooker on the bill? That could get some guys in trouble! lol
Thanks for the answer. Makes sense. It didn't look like it made any difference when I used it to pull the L98 out of my Y body. I'll probably never use it of an F body, at least not while I'm still in the UK.
