Catalytic Popcorn
Old Jul 12, 2010 | 09:11 PM
GACC's Avatar
GACC
Default Catalytic Popcorn
Have 87 stock when it warms sounds like metal popcorn coming from the under side dead center in the exhaust. Have a check engine on but don't
know the code yet. Catalytic converted bad?
Old Jul 12, 2010 | 09:35 PM
Harsh20's Avatar
Harsh20
any rattling noise from a converter means it should be replaced soon before it clogs up and leaves you stranded
Old Jul 12, 2010 | 10:24 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Hows your 79 running?
http://forums.corvetteforum.com/c3-t...post1569784400
Old Jul 12, 2010 | 10:25 PM
Rich Silvestris's Avatar
Rich Silvestris
St. Jude Donor '05
My 87's cat gave up the ghost a few years ago. Strangely it was right after a shop changed the clutch. I replaced the cat, but later found chunks of the honeycomb from the old cat crammed into the rear Y junction. The car never died because of it, but it ran a lot better after that stuff was removed.... and that funny noise went away too.
Old Jul 13, 2010 | 01:06 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Take something and bang on the pre cats that are located on the front Y pipe. I have a sound from mine that's like a rod knock at idle. If there is loose stuff in there you can hear it bounce around after you give it a good thunk. I scored a used catless precat for $100 and it should solve my problem. I am also replacing my injectors with FIC Bosch IIIs which should result in a smoother idle. Right now it sounds like it has a lopey cam in it.
If your main cat is bad then Corvette Central sells a high flow Magnaflow cat for $154 plus shipping.
Old Jul 13, 2010 | 06:45 PM
GACC's Avatar
GACC
Will check things tonite, found the cat from Central. Concern is the check engine light. Will follow that up Thur. Engine also has a little stutter at low idle. Likes to run fast. Gust replaced MAF and O2 sensor on driver side
To Catalytic Popcorn
