QA1 coilover problem
Old Jul 20, 2010 | 06:04 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Can you spin the top collar down?
There should be two, on for the mount, and one for the spring perch.
I have inverted shocks, so I spin the perch on the shock body down, if you can spin yours up, that will effect your preload.
Old Jul 20, 2010 | 08:54 PM
LD85's Avatar
LD85
Originally Posted by cdsmith
So, the extension simply screws on to the top of the shock? Is it that simple?
That makes my day
Yes, it is that easy, get the 2" extension, the 1" does not lift it much at all, and you can move your spring up as well,, when I did mine, taking one wheel off at a time, it took me @ 1 hour to do both sides
With the shock being on an angle, the lift will not be the full 2", but it could be 1-3/4
