FYI 84 Air pump removal
However, myself and a few others have one thing in common: the belt tends to stretch due to the lengh of run from the tensioner to the alternator.
Today I finally got sick of that problem and heres what i came up with. Total cost of material is $52.00 and 1 hour labor
Using the bracket that was for the Air pump itself.
Center hole tap out to 1/2 inch x 13 thread
Get these parts
Idler pulley
Door striker bolt kit
The pulley has a built in bearing, the striker kit uses a plastic bushing that will need to be pressed into the pulley. Very simple using some emery cloth and then some grease just press in with a bench vise.
At your local hardware store you can get a nice metal spacer that the bolt will fit into and a self locking 1/2 x 13 nut.
Cut the spacer to the length you want. The nut I'm using just as a lock just in case the bolt loosens up.
should look like this
End Result
And running
[YOUTUBE]<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/tvlfDmXAsuE&hl=en_US&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/tvlfDmXAsuE&hl=en_US&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>[/YOUTUBE]
