1986 Bose Wiring
Old Jul 19, 2010 | 09:47 PM
1986coupe's Avatar
1986coupe
Default 1986 Bose Wiring
I know that there are lots of threads out there about this but I have two wires that I can't find a reference to.
Someone cut the wires to put in some junk stereo years ago so I have the job of finding out what goes where. I have everything wired up except two.
Looking at the back of the Delco-Bose, there is a pink wire on the right and a black wire on the left. Does the pink wire go to the pink in the car? The black wire on the right, is it a ground? I ask this because the wire turn green as it goes into the radio.
Also, inside I can see a grey wire with a white stripe that doesn't seem to go anywhere.
Any help is greatly appreciated!
Thanks,
Bill
Old Jul 20, 2010 | 09:27 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
The pink should go to pink, for either the Bose relay or power antenna. I don't recall which is which, but if you look at the schematic for Bose, the terminal locations should answer both of your questions.
http://dankai.shawwebspace.ca/asset/...2155/radio.pdf
The schematic doesn't seem to show the grey/white wire, that goes to HVAC control head for the display dim circuit. You can see that wire in the C68 part of this link.
http://members.shaw.ca/dankai/HVAC%20Electrical.pdf
Old Jul 20, 2010 | 09:53 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Hijack - Does your car a manual transmission?
Old Jul 20, 2010 | 01:08 PM
1986coupe's Avatar
1986coupe
Automatic
Old Sep 1, 2013 | 09:43 AM
Robert Hammond's Avatar
Robert Hammond
2nd Gear
my 1986 corvette has great hard acceleration until it warms up-then when you stomp her nothing-like its starving for gas...any help is greatly appreciated
Old Sep 1, 2013 | 09:44 AM
Robert Hammond
2nd Gear
my 86 vette just doesn't want to start some times-plenty of power just nothing at the starter no noise or anything-then next time I try it fires right up????????
To 1986 Bose Wiring
