Engine Question
Old Jul 21, 2010 | 02:12 AM
rrwebster's Avatar
rrwebster
Default Engine Question
Is the engine out of a 1991 Trans Am GTA (350 tpi) the same as is a 1991 Corvette? If not what are the differences?
Old Jul 21, 2010 | 03:23 AM
vetteoz's Avatar
vetteoz
Vette L98 has alum heads , different EGR setup on TPI intake possibly higher compression
Old Jul 21, 2010 | 01:21 PM
GKK's Avatar
GKK
The 91 Vette L98 is Speed Density and uses a MAP (Manifold Absolute Pressure) sensor and the 91 GTA uses a MAF (Mass Air Flow) sensor.
Also, the 91 Vette L98 has 10.25:1 compression ratio and the 91 GTA has 9.3:1 compression ratio.
Old Jul 22, 2010 | 03:42 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
I just sold a 92 firebird TPI engine. It was map and had iron heads. the iron heads have a different intake bolt angle.
To Engine Question
