reading codes?
Old Jul 22, 2010 | 02:45 PM
joesgulfstream's Avatar
joesgulfstream
Default reading codes?
having gotten a check engin soon light come on during highway driving and more offen with the air on and also a little rough idle I used the paper clip method between 4 an 12 on my 95 LT1 auto this is what i came up with. what do they mean thank you
C 12
1
H 64
1
4
9
A
1.0
Old Jul 22, 2010 | 04:07 PM
aminnich's Avatar
aminnich
C12 means your computer is communicating properly
H64 means that at some point the right bank 02 sensor was reporting a lean condition. It is a history code. You can clear the codes and see if it comes back.
Afraid I have no idea about the other numbers it is giving you.
Old Jul 22, 2010 | 04:13 PM
joesgulfstream
How can I clear the codes ?
Old Jul 22, 2010 | 05:12 PM
aminnich's Avatar
aminnich
PM sent.
Old Jul 22, 2010 | 05:30 PM
joesgulfstream
#64: Bank 2 RF Heated Oxygen Sensor #1 Circuit Lean.
would this cause the check engine soon light at highway speeds after 20 minutes and a rough idle ? the code is H64 is the H (History) because the engine is off?
Old Jul 22, 2010 | 06:48 PM
rodj's Avatar
rodj
Different modules
Module 1 is the CCM module.
Module 4 is the PCM module
Module 9 is the ABS/ASR module
Module A is the DERM ( the air bag control module)
Old Jul 23, 2010 | 04:35 PM
joesgulfstream
ttt
To reading codes?
