REMOVING window tint
Old Mar 25, 2002 | 12:33 AM
rideklein's Avatar
rideklein
Default REMOVING window tint
Any pointers or good products out there for removing window tint film?
And if anyone's interested, I'll sell the removed film to ya! :bs
Old Mar 25, 2002 | 01:02 AM
Kevin 88's Avatar
Kevin 88
Default Re: REMOVING window tint (Seattle 6spd)
The tint is easy enough to peel off. The glue is another matter. I've tried all sorts of adhesive removers and none worked very well. You can scrape mos of the adhesive off with a razor blade, then resort to adhesive remover and lots of elbow grease.
It is very easy to scrape the defroster strips off the back window. I tried to be careful and still ruined two of the traces.
Old Mar 25, 2002 | 01:08 AM
rideklein's Avatar
rideklein
Default Re: REMOVING window tint (Kevin 88)
Geez, didn't think about the defroster. That area will be a challenge. :U
Old Mar 25, 2002 | 01:22 AM
JonM's Avatar
JonM
I removed my window, turned it upside down and used paint remover. Worked like a charm. Didn't hurt the defrosters because thay are cooked into the glass. I was going to paint the little flap on top of the window anyway, you would need to be careful and protect it. You can also try tintdude.com
Old Mar 25, 2002 | 11:32 AM
rideklein's Avatar
rideklein
Default Re: REMOVING window tint (JonM)
Seems like a good approach for the hatch. Any other input out there for the door glass???
I've done this once before on another car, and found there is a lot of labor in getting the adhesive off. :boxing
Old Mar 25, 2002 | 11:36 AM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
Door glass you can just scrape with a razor or peel it off and use some very fine steel wool along with glass cleaner to remove the glue.
Old Mar 25, 2002 | 12:11 PM
HiRiser's Avatar
HiRiser
Default Re: REMOVING window tint (Springer's 95)
I de-tinted mine. Just peel off the tint and use Castrol Super Clean (at WalMart) and the glue ***** up and comes off. I used about 3 rolls of paper towels. No blades or wool for me.
Old Mar 25, 2002 | 12:49 PM
RED92LT1's Avatar
RED92LT1
Default Re: REMOVING window tint (HiRiser)
Lacquer thinner works to remove the glue. You don't want to get it on plastic as it could soften it and you should try and keep off the rubber as well ... and wear gloves cause it has a tendency to dry your hands out. That it how I got the glue off of my back window and it didn't touch the defroster strips.
Brian
Old Mar 25, 2002 | 01:05 PM
mozot's Avatar
mozot
From what Ive been told from my buddies who own a tint shop, you should always heat up your windows first before you take off tint. So either do it on a hot day or bust out a heater, it will make the job easier. And watch out for the defoster lines, try not to work over them. Your tint looks like it is an aftermarket kit, so i dont think you would have any problem with glue. I didnt know people used glue to put on tint?????
By the way, good luck finding a hot day in the sun in Seattle :)
[Modified by mozot, 5:07 PM 3/25/2002]
Old Mar 25, 2002 | 01:18 PM
rideklein's Avatar
rideklein
Default Re: REMOVING window tint (mozot)
A bunch of good input -- thanks to all. Now I have some other tricks up my sleeve if something doesn't work.
MOZOT, on the adhesive - I think it's just provided with the tint. ??? Hey, and it's almost sunny today! :jester
Anyway, the tint looks nice, and most would like to see me keep it on. I'm just not a tint guy. I think clear windows make a car look a lot more clean and light.
Old Mar 25, 2002 | 05:52 PM
Tom 35th anniversary's Avatar
Believe it or not I peeled the old tint off fairly easily and then sprayed the glue down with 409 and it just wiped right off. I was really amazed it was so easy!!!!
To REMOVING window tint
