AC Compressor failure
Old Jul 22, 2010 | 05:55 PM
jakers's Avatar
jakers
St. Jude Donor '06
Default AC Compressor failure
I am working through some AC issues and I started thinking today that I don't really know the exact situation that occurs when an AC compressor fails. So now I am curious as to what actually happens when the compressor goes bad. I am guessing that in the worst case the compressor makes a single nasty noise then seizes and then the belt starts to smoke! I am guessing at this one, so what actually does happens?
Old Jul 22, 2010 | 07:17 PM
pmihaltian's Avatar
pmihaltian
Slingshot
The most frequent failure is the seals go bad and all the oil and Freon leaks out. With bad seals the compressor can not maintain a pressurized charge of Freon. You can usually tell if your seals are bad as there are tell-tail splatters of oil on the inside of your hood right above the compressor location.
Old Jul 22, 2010 | 07:54 PM
MotorCity_87_C4's Avatar
MotorCity_87_C4
Thanks, I cleaned my hood underside and there was goop just above the compressor. The AC would only hold a charge for a few days.... That explains that.
Time for an R134 conversion.
Old Jul 23, 2010 | 12:23 PM
redrose's Avatar
redrose
normal to have 'some' goo on the hood from a/c compressor weep.
most compressor failures are clutch malf.
second most common fail is simple wear internally.
rarely, the 'big bang' does signal hurt time.
need a 'gauge manifold' that displays compressor inlet and discharge pressures and Service Manual temp/humidity/press chart to tell if the compressor is healthy...hf has that for cheap $...get your current local ambient temp and esp humidity values from internet weather unless you own those.
To AC Compressor failure
