1992 gas gauge problems
Old Jul 22, 2010 | 10:45 PM
mobileman's Avatar
mobileman
Default 1992 gas gauge problems
Can't seem to get gas gauge to work it always reads empty. We even tried another sending unit out of a working car still no help. Even tried changing instrument cluster from working car still no help. Any ideas what to look for would be appreciated.
Old Jul 23, 2010 | 04:10 AM
pmihaltian's Avatar
pmihaltian
Slingshot
See the attached write-up.
Old Jul 23, 2010 | 07:44 AM
mobileman's Avatar
mobileman
I will do some more checking this evening but I would have thought if the sending unit was bad it would have fixed it swapping it out from the other car because the guage works properly on the other car.
Old Jul 23, 2010 | 11:15 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
When you swapped it back does it still work in the other car?
If so then you have a wiring issue between the tank and the gage.
Time to brake out the wiring diagram and the DVOM
Old Jul 23, 2010 | 11:54 AM
mobileman's Avatar
mobileman
The instrument cluster and sending unit both worked when we put them back in the other car. Shouldn't there be some voltage on the sending unit wire going back to the cluster?
Old Jul 23, 2010 | 12:07 PM
mobileman's Avatar
mobileman
The other car is an 89 but we noticed that on the 89 with the sending unit unplugged the gauge would peg and stay there with the key on and on the 94 it would stay empty. It seems like the wire is shorted somewhere.
To 1992 gas gauge problems
