Where is the Service Parts Identification Label on 87 Vert
St. Jude Donor '10
Can't find this anywhere.
I am trying to determine what my diff ratio is. It is apparantly on this label as one of the Regular Production Options (RPOs).
St. Jude Donor '10
So both rear wheels off the ground, transmission in neutral, park brake off. I am a bit worried the car will move without any brakes on. Is chocking the front wheels good enough?
chocking the wheels should be fine. or you can set the cruise control at and note your speed and rpms and plug that in with your tire size in one of the 9 million gear ratio calcs on the internet. good excuse for a drive
Set the cruise at 70 MPH
If it turns 2000 rpm, it is 3:07 gears
If it turns about 1700 rpm's, it is 2:59 gears.
Except for the verts that had 2:77's, those were the only 2 gearsets available in a c4 auto car.
