Adjusting idle speed?
Old Jul 27, 2010 | 08:24 PM
Left Hand Drive's Avatar
Left Hand Drive
Default Adjusting idle speed?
My idle is to low at 400-500 rpm how can adjust the idle to 600-700 rpm?
Its a 86 with 145K
Old Jul 27, 2010 | 08:55 PM
rodj's Avatar
rodj
Idle speed is set by the computer but you can cheat
http://www.corvetteactioncenter.com/...and+Idle+Speed
Yours the only C4 in Tonga?
Not too many roads for doing 150mph on ?
Old Jul 27, 2010 | 09:07 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
He says 2 on the island.....see profile.
Old Jul 27, 2010 | 09:42 PM
Casket86's Avatar
Casket86
I just performed that process yesterday. Worked like a champ.
The Tonga Corvette Club sounds mighty small.
Old Jul 27, 2010 | 10:57 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
If it's an 86 with the original automatic trans, it will jerk into gear at that speed. the 500 is a good number if the idle air control valve is good.
To test the idle air control valve, start the car, let it idle. wait til it lowers the idle to 500 after the self tests are over.
now turn on the air conditioning.......500 RPM's........turn off the air conditioning........500 RPM's.
Turn on the air conditioning.......500 RPM's.....put the car in gear.............500RPM's.
all is good.
If you get 500 RPM's and turn on the air conditioner and the engine dies, the idle air control valve is not working. If you put the car in drive and the engine lopes or dies, it's the IAC again.
Old Jul 28, 2010 | 04:10 PM
aklim's Avatar
aklim
If I wanted to change the idle speed for some reason, I would get the guy who programmed my chip to do that. By cheating and forcing it into the speed you want, all you are doing is eliminating the IAC altogether. Fine if you don't have varying conditions.
Why do you want a higher idle? All that does is slam the gear harder.
To Adjusting idle speed?
