90 L-98 Knocks for 20 seconds after start?
Old Mar 25, 2002 | 03:31 PM
thnbluline50's Avatar
thnbluline50
Default 90 L-98 Knocks for 20 seconds after start?
First of all I want to say hello to all. Although I am a new guy on the forum I have been lurking in the background for a while getting A LOT of great tips from the masters!
Here goes: My 1990 L-98 has a loud knocking at start-up. It ONLY happens when cold outside, (not to be confused with just "cold" engine) Hard to tell where the knock is coming from, specifically where in the engine compartment but it is loud enough to hear inside.
Strange thing is, after approximately 20 seconds, no knock at all and it purrs like a kitten.
just in case anyone needs this info to diagnose (spelling) I cant identify any engine mods it may have had in the past, IE heads, cam valves etc. I bought it used 8 months ago and it's been too cold to really get into it. :chevy
Old Mar 25, 2002 | 03:32 PM
scorp508's Avatar
scorp508
How cold outside are we talking? Is it piston slap or ignition knocking? What oil are you using?
Old Mar 25, 2002 | 04:00 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Default Re: (scorp508)
Thinking about piston slap,and you havent had the car long,any idea if the motor was ever rebuilt?Sometimes a rebuilt gets forged pistons and can have that slap on cold start up for a little bit then quiets down.
Anmyways hope it isnt anything to worry abut.May help to describe the sound more and or possibly pinpoint exactly where its coming from when its warmer out to check it.
Btw,welcome to the forum.
Old Mar 25, 2002 | 04:30 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Default Re: (Bill's86Coupe)
Piston slap from a forged psiton isn't that loud usually and won't go away so fast. Might be a rod rap, which means the rods are hammering the bearings. When you drain the oil, is there any trace of silver in it? Motors with bad bearings usually show signs of wasted bearing, looking almost like silver paint was mixed in the oil.
Old Mar 25, 2002 | 04:45 PM
VMAX451's Avatar
VMAX451
Default Re: 90 L-98 Knocks for 20 seconds after start? (thnbluline50)
Is it really knocking or is it more of a ticking/tapping noise? May be as simple as running the wrong weight oil, causing the lifters to run dry for half a minute upon cold startup when the oil is too thick to flow. Also oil filters without anti drainback valves could cause the same problem. Just some ideas, hope it's as simple as an oil and filter change.
Old Mar 25, 2002 | 04:50 PM
DOCTOR J's Avatar
DOCTOR J
Take a look at the serpentine belt tensioner. If it's too close to it's upward limit stop, a cold belt will make it clank on start up - usually because an aftermarket belt was installed that's a little too long.
Old Mar 25, 2002 | 07:24 PM
KYVette90's Avatar
KYVette90
Default Re: 90 L-98 Knocks for 20 seconds after start? (DOCTOR J)
Check your harmonic balancer. The outer metal balancer has a tendancy to slide back towards the timing chain cover and hit the cover. If its not that, I'd say you have a bad bearing and the knock is a rod. My buddy had the same problem and a week later the knock was constant. Time for a rebuild.
Old Mar 26, 2002 | 04:25 PM
thnbluline50
About 40 degrees. Also I dont know hhat oil is in it. The guy I bought it from had just changed the oil right before I bought it. I am thinking of going to that Royal Purple stuff. Any thoughts?
Old Mar 26, 2002 | 04:28 PM
thnbluline50
Have no ideas if the engine has been worked on. Got it off a guy who caught his wife cheating and he wanted to dump it before he filed for divorce, and she took it. He bought from a private owner in California one year prior.
I took it out today and again, it knocked for 20 seconds and then nothing. It does run excellant and there is difenately no loss of power on the road.
Old Mar 26, 2002 | 04:45 PM
pablocruise's Avatar
pablocruise
Default Re: (thnbluline50)
first off, Welcome! Glad ya decided to join. Wave at other Vettes on the road :seeya :chevy
Can ya get like a mechanic's stethoscope or put a piece of pipe to your ear and probe around? I once had an EGR valve that would rattle(but that was only with lots of throttle since it doesn't operate at idle). Pre-cats not rattling? I wonder if the knock sensor is picking it up and retarding. How does motor run if you un-plug the EST connector?
Old Mar 26, 2002 | 05:15 PM
thnbluline50
Default Re: (89 Paul in cal)
I decided what I am going to do! Since the Semi comes in a few days to take it away (I am moving back to Ohio from Colorado) I am going to call my good friend back home in ohio to look at it. He builds engines for NHRA racers and has had built/rebuilt many ZR1s. I DO thank ALL of you who replied and I am really enjoying this site. :crazy:
To 90 L-98 Knocks for 20 seconds after start?
