Bad fuel pump?
Old Jul 29, 2010 | 01:57 PM
Rbuet's Avatar
Rbuet
Default Bad fuel pump?
Do I have a bad fuel pump???
1995 Lt1.
I have no (zero) fuel pressure at the schrader valve when I put the key into 'run' position without starting the car.
It takes too much cranking before the car starts.
42 PSI when the car is running.
Zero fuel pressure immediate after engine is stopped.
Do I have a bad fuel pump? Other?
Thanks in advance,
Ron
