PCMforless Question
Old Jul 31, 2010 | 11:50 AM
CAJUN C4's Avatar
CAJUN C4
Default PCMforless Question
How can PCMforless do a tune with not having access to the Vehicle?
How accurate can they be?
Thanx
Old Jul 31, 2010 | 11:58 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Thanx
Both of my Vettes are PCMforless tuned.
To include my modded LT4. I'm not an expert on tuning but, even some C5 and C6 owners do the mail tuning.
I dynoed tune my 95 two years ago and the AFR was right on
I had that question once about PCMFL but, the fact is that both of my Vettes run great whith their tune.
Old Jul 31, 2010 | 12:15 PM
94roseman's Avatar
94roseman
i just got my tune from pcmforless and it was a noticable differnece in the drivablity of the car...not sure if it gained power but tamed my cam alot.
i have very happy with my tune
Old Jul 31, 2010 | 01:41 PM
383vett's Avatar
383vett
Alvin has tuned thousands of cars over the years, some of them on a dyno. They have huge database and know what works and what doesn't. They are usually very good with their tunes.
Old Jul 31, 2010 | 03:15 PM
Red Rocket's Avatar
Red Rocket
The wizard of LT1 tuning is Moe Bailey in San Antonio, TX. He goes by MoeHorsepower. Alot of the fast F body LT1 guys use him. Lloyd Elliott recommended him with my 396 upgrade.
Did a mail order tune with Moe and dyno'd the car at a local dyno. Sent Moe the dyno sheets with the A/F. Mailed him the computer back and he tweaked it some more at no charge. The car ran great after the first mail order. Picked up another 5HP/TQ after the 2nd mail order.
Still plan on a dyno tune with Moe to pick up a few more HP up top but really not necessary.
Old Aug 1, 2010 | 09:31 AM
Irishpilot03's Avatar
Irishpilot03
I used them when I installed LT headers/cat delete. They emailed me the tunes and I uploaded them with my laptop. It took a few tunes, but they were very helpful with sending re-tunes until it was right. I recommend them for mail-order tunes.
Old Aug 1, 2010 | 11:02 AM
LT4BUD's Avatar
LT4BUD
Thanx
After my last set of mods I used a "mail order" tune from PCMforLess and then later had a dyno tune by PCMforLess.....the "mail order" tune was basically right on, they did some minor tweaking on dyno day in the mid rpm range..
Bottom line they got VERY close to an optimum tune for me, dyno tuning really wasn't needed....
If you fill out their information sheet with good information, they should be very accurate...
Old Aug 1, 2010 | 06:25 PM
1963SS's Avatar
1963SS
Bryan (PCM for less) has done many dyno days all over the country. He has tuned just about every combination of engine components possible. He keeps these records and when you fill out a questionairre he refers to a similar setup as yours that was tuned and proven on a dyno day. He's really good.
Old Aug 1, 2010 | 08:05 PM
94vettelover2's Avatar
94vettelover2
I also wondered how they know/knew what to adjust without them having the car.I don't think anyone answered this ? yet.Do you hook up something to the diagonstic port & then send them that after driving around & from that they see the fuel tables or something else.How do they know how your car is running(rich or lean) & adjusting the tune accordingly?Do you tell them your mods you have done to your car before the tune?I think it has something to do with datalogging but am not sure how it works.Can someone explain what they did thoughout the whole process when their car was tuned?
Old Aug 1, 2010 | 08:24 PM
JAKE's Avatar
JAKE
Stop by their website, log onto the Ordering Sheet page and take a look at the questions being asked. That'll give you a good idea of what mods, etc., have (or have not) been done that are important to tuning. One can't help but conclude that, based on the questions being asked, those are the areas important for him to have a response.
My view is that two of most important things for either Alvin or Bryan to know are cam specs and head flow numbers.
Jake
Old Aug 1, 2010 | 09:02 PM
94vettelover2
Originally Posted by JAKE
Stop by their website, log onto the Ordering Sheet page and take a look at the questions being asked. That'll give you a good idea of what mods, etc., have (or have not) been done. One can't help but conclude that, based on the questions being asked, those are the areas important for him to have a response.
Jake
Is that all they ask?
Old Aug 1, 2010 | 09:06 PM
Red Rocket's Avatar
Red Rocket
When you answer these questions, they can get close.
>> Year: 1994 LT1 Corvette
>> PCM: OBD1_____ or OBD11_____
>> Cam Spec: Duration____
>> LSA_____
>> Compression:___
>> Cubic Inch:______
>> Injector Size:________, Brand:________
>> Fuel Pressure:Stock:___/Other:__
>> Heads:Stock:____/Ported:Yes____/No:____ Aftermarket:___/Intake Runner
flow numbers:_____
>> Size:___cc Chamber________
>> Transmission: A4:_______/M6:______
>> Rear Gear:________
>> Tire Size:__
>> Forced Indction:Yes:___/No:___
>> Turbo:__no_or Supercharger:__no_
>> How many pounds:______
>> Forced Inducted Tune:__no__or Timing Retard Box:____no___
>> Nitrous:Yes:____/No:___
>> Nitrous Tune:Yes:___/No:__
>> Nitrous Shot:___________
As mentioned before, you should at least dyno the car and send the dyno sheets with AFR after first mail order tune. Took my car to the track after the first and 2nd mail order tune and knew right away the car picked up some HP.
Old Aug 2, 2010 | 01:34 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Thanx
1. You record the data stream from the ECM with a recording program like DataMaster.
2. You send the datalog to PCMforLess
3. Alvin or another tech runs the datlog and makes changes to your tune.
4. PCM emails the tune back.
5. You load the new tune into your ECM.
6. You record another datastream and email it back.
7. This goes on until your happy with the performance and Alvin says Thats a wrap!
My runs consisted of a 55 & 65 MPH typical driving & a 0-100 run.
Old Aug 2, 2010 | 01:54 AM
Irishpilot03
I used Datamaster. My first tune caused the car to backfire at WOT so I datalogged a few runs and they corrected off of my data. You do this via your own laptop with appropriate USB cable.
To PCMforless Question
