Coolant Temp Sensor Disconnected (?)
Old Aug 1, 2010 | 02:31 PM
JAKE's Avatar
JAKE
Default Coolant Temp Sensor Disconnected (?)
Okay, here goes: In the process of trying to diagnose some engine issues with my son's 96 LT1 via telephone, he told me that the connector to the CTS in the PASSENGER SIDE head has NO WIRE coming from it.
Just the sensor and connector - but NO wire. So I asked if both gages are working and he verified both the digital AND the analog gages are working.
I can't understand how that can be; wire disconnected but gages work.
Any thoughts on this?
Thanks,
Jake
Old Aug 1, 2010 | 03:13 PM
STL94LT1's Avatar
STL94LT1
Hmmm, that doesn't make sense. With the temp sensor in my 94 disconnected, the analog gauge does not work. There is only one wire for the coolant temp sensor in the head. Maybe he saw one and thought it needed two?
Old Aug 1, 2010 | 04:56 PM
vette079's Avatar
vette079
And you are 100% sure it´s the CTS sensor he´s looking at?
Is there another sensor on that side/another thing on the car wich is not working?
Old Aug 1, 2010 | 05:04 PM
383vett's Avatar
383vett
On the earlier C4s, there were 2 temperature sensors, one for the dash and one for the ecm. The one in the head was for the dash. The one in the front of the manifold was for the ecm. Not sure about the LT1s.
Old Aug 1, 2010 | 08:09 PM
JAKE's Avatar
JAKE
Well, he's at Ft. Lee in VA and I'm in TX so I can't actually SEE, but he said he ran his hand over the connector and reported NO wire.
I had him check both TEMP GAGES and BOTH are reporting temps, so I'm confused, too. I tried finding something in the FSM on this didn't find anything that would help. I was pretty tired at the time so that accounts for it.
I suspect the single wire (he and I both know it's only a one-wire connector) is for the analog gauge, not the digital, but haven't found anything, yet, to confirm that.
So the question remains "How could the gages be working with that sender wire NOT connected?
Oh, BTW, LTs have one sensor in the water pump that is used by the PCM for it's operation and there's a SENDER in the Passenger side head is for the dash gages. I don't know if the PCM even accesses the head SENDER.
From my reading on this, the one in the head is a SENDER, as opposed to a SENSOR.
Strange.
Jake
Old Aug 2, 2010 | 03:48 AM
vette079's Avatar
vette079
Thanks,
Jake
Ok, time for a dumb question now.
He (your son) says that both analogue and digital gauges are working.
I assume he has the C68 AC with digital readout?
Did he just look at the digital readout, or did he actually press and hold the fan up/down buttons, followed by pressing the up button to number 16 and then the auto button once, to find out the engine temp (Celsius)?
If "the digital gauge works", what readout did he get?
If nothing connected on either sensor, it can´t be much more than the outside temp, if he didn´t press any buttons.
Old Aug 2, 2010 | 04:34 PM
thedudeman321's Avatar
thedudeman321
The sender in the passenger head controls nothing but the analog gauge on the dash. The one with the needle, not the one that you can show on your speedometer screen. to clear any possible confusion. If that gauge works, then the wire is there and connected. Its probably just bent down and tucked under the sensor. It's then routed behind the exhaust manifold, so I could understand it being hard to see.
Old Aug 2, 2010 | 05:26 PM
94vettelover2's Avatar
94vettelover2
Ask your son the color of the wires going to that suspect sensor & someone here with a wiring diagram can verify by the color of the wires if that is the correct sensor.
Old Aug 2, 2010 | 05:48 PM
vette079's Avatar
vette079
Darn, didn´t know that you could show it on the speedo, thought they were all the same from 90 on.
Old Aug 2, 2010 | 06:09 PM
thedudeman321
If I recall correctly the wire is supposed to be (dark)green, but mine came wrapped in its entirety in grey/black thermal insulation, due to the proximity of the exhaust.
Old Aug 2, 2010 | 06:17 PM
JAKE's Avatar
JAKE
That's the problem, he claims there is no wire there to check. Yet when were on the phone and he had the engine idling, he reported the analog temp gauge temp reading was increasing as we spoke.
Anyway, the wire must be connected and since he's getting temp readings I'm not going to concern myself about it right now. Next time he's under the car I'll have him look very carefully for the wire.
Thanks for the responses.
Jake
Old Aug 2, 2010 | 06:19 PM
JAKE's Avatar
JAKE
Yep, you may well be right about that. We'll know for sure when he puts the car on the hoist in a few days.
Jake
To Coolant Temp Sensor Disconnected (?)
