I picked this up yesterday and it works great. Easiest tool I have found to get on the plug and has the best clearance. The latest mailer I got has it on sale for $19.95 and is less than $16 with the 20% coupon. http://www.harborfreight.com/21-piec...set-93150.html
I like the go thru design, I may just pick up a set myself...I have so many Harbor Freight coupons lying around.
Personally, I use a Craftsman 3/8 drive with flex head and long handle. http://www.sears.com/shc/s/p_10153_1...5&blockType=G5 It gets the job done with no knuckle busting, its like my favorite tool. Before I got it, I had to use a regular size 3/8 drive, a t-handle speedwrench and load of extensions.
Most of my little BS tools, pry bars and weird handy tools come from HFT
- most of my "occasional use" tools come from HF - 20% off coupons are all over the place. i recently bought a metric service wrench set for $25 out the door just because i needed a 27mm to remove the oil pressure sensor. it would have cost me that to get a single snap-on wrench.
I have been looking for the coupons, where can I find one?...WW
After I installed TPiS headers on my 85 straight plug heads, I could not get a spark plug socket on a few of the plugs. I ended buying a spark plug socket with a hex end for an open end wrench. Then I shortened the socket about a 1/4 inch and slotted a side wide enough to slip over the plug. There's just enough room to get a shorty open end wrench on the socket. I can now change plugs just as fast as the stock setup.
Thanks Jake, I just went to Harbor Frieght and ordered the socket set, I had a catolog here that had a (Key Code) that I had to enter to get the set for $19.95..Without the code it would have cost me $29.95..WW
......within a few miles of the local HF are closed Ford, GM and Chrysler plants along with Steel Mills, etc
...the HF in Mansfield is within sight of the now closed GM plant...
and your point is - ??? where's your TV made? how about your DVD player, your computer, your wifes microwave? i'm guessing you never bought anything made in china - ??? i doubt very seriously that HF had anything to do with gm, ford, and chrysler plant closings.
the wheels on my 2008 C6 are stamped "made in taiwan" - go figure... gm doesn't seem to have a problem using frickin' chinese parts, yet i sense you seem to have issues with me buying a chinese wrench - - now this, i don't get...
there's probably is a best buy within a stones throw of those closed plants selling all that foreign made $hit too - them ba$tards!
