Distributor and Balancer Experts Help!
Old Aug 4, 2010 | 10:06 PM
Pwnage1337's Avatar
Pwnage1337
Default Distributor and Balancer Experts Help!
I have been having problems with my 85 running rough lately. I decided to check the timing (for the 50th time) today.
I noticed something strange. If I set the car at 6 degrees BTDC, with the EST disconnected, at idle it will stay at 6 degrees, if I open the throttle up to about 1500 rpm, the balancer mark goes past the 12 degree btdc mark (my guess would be around 16 degrees btdc.) It goes even farther if I open it up more.
Isn't the timing supposed to stay dead on at 6 degrees no matter what RPM the engine is running?
Slipped balancer? Something wrong with distributor? Timing chain?
The car is tired, so there could be multiple problems here.
Thanks,
Jeremy
Old Aug 4, 2010 | 10:22 PM
92WhiteVetteGuy's Avatar
92WhiteVetteGuy
Hi,
Almost always with a few exceptions a internal gas combustion engine requires the spark lead/advance to increase with rpm. This is due to the relatively decresed time for combustion to occur. Also power and efficiency increases with timing.
Sounds like everything is normal.
92WhiteVetteGuy
Old Aug 4, 2010 | 10:57 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Well said in the post above. If you look at the ECM timing tables, you'll find as much as 40-42 degrees advance "programmed in". What you saw is normal. rpm and load both play a role in spark advance.
And, from what the TGO guys tell me, vettes have more advance than their counterpart F-body cars.
Old Aug 4, 2010 | 11:14 PM
Pwnage1337's Avatar
Pwnage1337
Okay so that is normal for the car to have the advance without the EST. Can anybody tell me why my car is slow? Its like the car isn't getting spark advance, it doesn't have hardly any pickup.
I can't even spin the tires with my foot on the brake at WOT.
Old Aug 4, 2010 | 11:25 PM
mseven's Avatar
mseven
no the timing will move past 6* w/est disconnected when the rpm increases even when standing still and with minimal load changes.
I can't tell you why it won't spin the tires or is slow...sounds as though timing isn't the problem. It wouldn't be a a bad idea to get a scan/datalog to understand everything else that is going on.
Old Aug 4, 2010 | 11:30 PM
bwiencek's Avatar
bwiencek
with the connector DISCONNECTED the spark advance should be "0" meaning that the spark will stay at the set timing regardless of what engine RPM that it is revved to - only when the computer is "CONNECTED" will the spark tables come into play and advance the timing.
I'd check the ignition module as I've seen other GM ones exhibit similar random timing events before going out - also if it's bouncing around a lot then check the timing chain for slack (you can pull cap, turn engine clockwise then counter clockwise and look for rotor movement) and check for loose distributor bushings.
OH - and if it was balancer - it would slip and look like it was advanced but NOT return to base reading.
Old Aug 4, 2010 | 11:34 PM
rodj's Avatar
rodj
But FWIW just checked mine out of interest and it does the same as OP's.
With ESC disconnected ;static @6 ; goes to 12 when reved ('90 w/ 50K)
Old Aug 4, 2010 | 11:48 PM
Pwnage1337's Avatar
Pwnage1337
I can datalog it with tunerpro rt. My BLMS are all over the map. It all started after the super ram swap, i can't find any vacuum leaks but there could be one.
As far as the timing chain goes would it be worth it to replace it? what kind of project am i looking at?
I want to build a 383 soon, I am stacking parts (just bought heads, Super ram, have crank & block) because i know this 350 is on its last leg.
This is what I have replaced:
Ignition module (tooth thing in dizzy)
Fuel pump
Fuel filter
ECM
cleaned off 2 grounds
cleaned MAF
replaced CTS (after old ECM told me it was -40 degrees)
Old Aug 7, 2010 | 05:14 PM
GREGGPENN's Avatar
GREGGPENN
I was trying to confirm this in another thread. You just disconnect your EST (4-wire connector to dizzy) to perform timing? You don't have (or don't use) the mysterious timing connector I can't seem to find in my 89?
To the OP: The FSM says there is a backup system to provide ignition advance in the event the EST fails. It doesn't' say how/where, but you'd have to think it was mechanical in the distributor. That must account for the (small) advance seen when the EST is disconnected.
Old Aug 7, 2010 | 05:28 PM
JAKE's Avatar
JAKE
LOL. Where DOES some of this stuff come from???
With my 86 Vette I use to play with the initial timing all the time with the timing connector disconnected. Tried the stock 6 Degrees BTDC, 8, 10, etc. Guys do this all the time.
Once done I locked down the dizzy, verified the setting hadn't changed, shut down the engine, reconnected the timing connector, cleared the stored and done.
Well, done except for the test drives with Diacom up and running while I logged and watched for knock retard.
Jake
Old Aug 7, 2010 | 06:56 PM
GREGGPENN's Avatar
GREGGPENN
Did you even read this thread, Jake?
If so, I'd be really curious what the heck you just responded to.
Old Aug 7, 2010 | 07:02 PM
383vett's Avatar
383vett
Jake's enjoying the weekend. Gregg, did you find your missing connector yet. I still say you have to look inside your bellhousing.
Old Aug 7, 2010 | 07:04 PM
vetteoz's Avatar
vetteoz
If you disconnect the 4 wire HEI plug you have no reference signal to ECM to fire the injectors
Look harder
Old Aug 7, 2010 | 07:20 PM
GREGGPENN's Avatar
GREGGPENN
Thanks! I just found that connector taped to the back/underside of the fuel-pump harness. I didn't expect to find it on that line. Weird.
Look harder
Old Aug 7, 2010 | 07:22 PM
383vett's Avatar
383vett
Horray
Old Aug 7, 2010 | 07:26 PM
GREGGPENN's Avatar
GREGGPENN
Originally Posted by 383vett
Horray
Wait for me to catch up Jake!
Old Aug 7, 2010 | 09:02 PM
JAKE's Avatar
JAKE
Fuel pump
Fuel filter
ECM
cleaned MAF
No, that's not the module. The module is the flat, slightly rounded black piece bolted to the dist with two small bolts/screws. Has a couple of electrical plugs connected to them.
Jake
To Distributor and Balancer Experts Help!
Old Aug 7, 2010 | 09:07 PM
JAKE's Avatar
JAKE
WhadIdo?
Jake
Old Aug 7, 2010 | 09:10 PM
JAKE's Avatar
JAKE
LOL, yep, that would be me. Heading to the frig now for another Cold Bud.
Jake
Old Aug 7, 2010 | 09:55 PM
GREGGPENN's Avatar
GREGGPENN
Originally Posted by JAKE
WhadIdo?
Jake
Fur-as-I could tell, your first post talked about it being O.K. to experiment with initial timing while the OP asked if timing should bounce around with the timing connector disconnected.
I don't see the connection.
