Bad gas mileage
Old Mar 26, 2002 | 05:35 PM
vetteman32's Avatar
vetteman32
Default Bad gas mileage
This is a question on my 91 truck. It's a Chevy with a 350 so I figured you guys could help. Sometime during the winter, my gas mileage dropped from it's typical import mileage of 14-15mpg down to about 10mpg :eek: . I gave it the basic tune-up (plugs, wires, cap & rotor, air filter, pcv) about 2 weeks ago, but have not seen an improvement? Any ideas? Thanks!
Old Mar 26, 2002 | 05:49 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Bad gas mileage (vetteman32)
When gas mileage drops I suspect the O2 sensor(s). A scan tool would tell you if it was going closed loop or not.
My '86 IROC had a bad O2 sensor and wouldn't go closed loop and didn't throw a code either. I discovered the problem after it failed emissions and I put a scanner onto it.
Old Mar 26, 2002 | 09:03 PM
C4396roadster's Avatar
C4396roadster
during the colder months aka winter usually all gas companies switch to oxygenated gas for emmissions
Old Mar 26, 2002 | 09:24 PM
traxx1's Avatar
traxx1
You probably have a 160 degree stat and it doesn't let the ecm work properly :jester :jester :jester :jester :jester :jester
To Bad gas mileage
