1986 Corvette Fuel Pump Relay Location
Old Aug 9, 2010 | 06:12 PM
Aopsahl7's Avatar
Aopsahl7
Default 1986 Corvette Fuel Pump Relay Location
I have googled and searched far and wide, and I have yet to come up with a solid answer.
Who knows where this thing is. I have found two relays one that is bolted onto the drivers side front wheel well, and then one that is bolted onto the passenger side firewall.
Any help?
Old Aug 9, 2010 | 06:59 PM
jon0108's Avatar
jon0108
it is on the firewall, right next to the brake booster. The one you mentioned on the wheel well is for the fan
Old Aug 10, 2010 | 08:27 AM
JAKE's Avatar
JAKE
Yep, that's where it is. Firewall, just inboard of the power brake booster.
Page "6E3-A-2, DRIVEABILITY AND EMISSIONS - FUEL INJECTION (PORT). "Y" Series RPO: L98 VIN CODE: 8 5.7L V8 PFI
Figure A-1 - 5.7L Component Locations "Y" Series" diagram lists it's position as "3. Fuel pump relay".
Information taken directly from the 1986 GM Factory Service Manual for the 1986 Chevrolet Corvette. Dated 10-29-85 Diagram ID # *55 2129-6E
How's that for a "solid" answer?
Jake
Old Aug 10, 2010 | 09:59 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Save this to your PC.
http://members.shaw.ca/corvette86/Co...0View%2086.pdf
Old Aug 10, 2010 | 10:10 AM
Aopsahl7's Avatar
Aopsahl7
Thanks fellas. Always helpin out
Old Aug 10, 2010 | 04:31 PM
JAKE's Avatar
JAKE
Originally Posted by AGENT 86
WAY TO GO! Wish I knew how to do that, LOL
Jake
Old Aug 10, 2010 | 05:50 PM
megtom2's Avatar
megtom2
I hope the wires are not melted away from your connector like mine were. Lucky it hadn't sparked up real bad.
Old Mar 20, 2013 | 06:01 PM
rich 1st's Avatar
rich 1st
6th Gear
thanks really helped in locating the relays
To 1986 Corvette Fuel Pump Relay Location
