Quick 1985 4+3 Fluid Change Question
Old Aug 9, 2010 | 06:39 PM
gkrynick22's Avatar
gkrynick22
Default Quick 1985 4+3 Fluid Change Question
I am currently changing the Gear Fluid and Transmission Fluid in my Vette. I filled the Gear fluid and went to fill the transmission fluid and noticed there is no filler neck under the hood. I looked around and saw a plug similar to the gear filler plug on the driver side of the transmission. Is this where you fill the transmission? I would assume it is the same method as the gear oil (fill until it reaches bottom of the hole with manual pump), but I wanted to verify this before i screw up my tranny. I searched like crazy (Google and here) and found nothing. Any help would be appreciated. Thanks
Old Aug 9, 2010 | 09:44 PM
rodj's Avatar
rodj
Correct
Some disconnect the cooler line from O/d at the radiator and fill through the line until fluid comes out the open plug hole in O/d unit
Old Aug 9, 2010 | 10:30 PM
gkrynick22's Avatar
gkrynick22
Originally Posted by rodj
Correct
Thanks rodj! I have everything else done, I was just waiting for conformation before i did some stupid damage. Time to button her up and give her a test run.
To Quick 1985 4+3 Fluid Change Question
