testing IAC?
Old Aug 10, 2010 | 01:37 AM
littleredcorvette88's Avatar
littleredcorvette88
Default testing IAC?
is there any way to test whether or not the IAC is working properly?
thanks
Old Aug 10, 2010 | 03:32 AM
corvette95's Avatar
corvette95
Without a tech1a scan tool, you can do the minimum idle reset proceedure, do a quick forum search for the details, Basically, turn on ignition- dont crank, wait 30 sec. unplug IAC, THEN unplug spark advance connector (brown and black I think stripped wire by windshield wiper motor), start car, set idle torx screw on throttle body to idle speed of 450 rpm, yes 450 rpm - may die a time or two but shouldnt, THEN take either an ohm meter or tech1 and loosen TPS sensor - slide up either director to get a reading of .54 to .56 then tighten.
replug IAC and spark advance - car should slowly go to 650 rpm smooth idle. This should verify IAC operation. If ok, disconnect battery to clear code set from unpluggin spark advance earlier. - 5 minute job with TPS harness tester ($20 from ecklers). Good Luck!
Old Aug 10, 2010 | 04:55 AM
Charleston2012's Avatar
Charleston2012
thanks
http://shbox.com/1/iac2.jpg
Old Aug 10, 2010 | 10:02 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/agent86/IAC%20Diagnosis.pdf
To testing IAC?
