quick question regarding pickup coil
Old Aug 10, 2010 | 01:35 PM
in-vette-uation's Avatar
in-vette-uation
Default quick question regarding pickup coil
I'm getting infinite ohm reading when performing "test 2" between the two terminals. Does this mean I need a new pickup coil or could I somehow screw up this simple test?
Old Aug 10, 2010 | 03:45 PM
in-vette-uation
It would make sense since I have a no spark no spray condition on my '84. I had the ignition module tested and it passed with flying colors.
Old Aug 10, 2010 | 04:44 PM
OkieC4's Avatar
OkieC4
I just did a pickup coil test on my 91. Test 2 tests coil windings and wires for continuity, including during the "shake test". You should be seeing a steady ohm reading somewhere between the 500 and 1500 range with the ohmmeter leads connected to the green and white (or off white) wires. With the ohmmeter I had, I used the 2K ohm setting and read a steady 854 during the shake test.. Sounds like your has opened.
Old Aug 10, 2010 | 04:50 PM
in-vette-uation
Thanks Okie, I agree. I'm not getting any reading other than infinity moving wires or not. I ordered a new pickup coil today.
Old Aug 15, 2010 | 10:17 AM
in-vette-uation
sure enough was the pickup coil. car is happy as a clamshell could be!
To quick question regarding pickup coil
